Colegas, estou tentando fazer um ssh de uma máquina qualquer para o meu servidor que eu chamo de nxserver, mas quando eu vou dar um ssh, ele me retorna este erro:
ssh_exchange_identification: Connection closed by remote host
seguem alguns dos meus arquivos para análise:
--- começo de hosts.allow ---
# hosts.allow This file describes the names of the hosts which are
# allowed to use the local INET services, as decided by
# the '/usr/sbin/tcpd' server.
# Version: @(#)/etc/hosts.allow 1.00 05/28/93
# Author: Fred N. van Kempen, <[email protected]
ALL : ALL : ALLOW
# End of hosts.allow.
--- final de hosts.allow ---
--- começo de hosts.deny ---
# hosts.deny This file describes the names of the hosts which are
# *not* allowed to use the local INET services, as decided
# by the '/usr/sbin/tcpd' server.
# Version: @(#)/etc/hosts.deny 1.00 05/28/93
# End of hosts.deny.
--- final de hosts.deny ---
--- começo de /etc/ssh/sshd_config ---
# $OpenBSD: sshd_config,v 1.72 2005/07/25 11:59:40 markus Exp $
# This is the sshd server system-wide configuration file. See
# sshd_config(5) for more information.
# This sshd was compiled with PATH=/usr/local/sbin:/usr/sbin:/sbin:/usr/local/bin:/usr/bin:/bin
# The strategy used for options in the default sshd_config shipped with
# OpenSSH is to specify options with their default value where
# possible, but leave them commented. Uncommented options change a
# default value.
#Port 22
#Protocol 2,1
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
# HostKey for protocol version 1
#HostKey /etc/ssh/ssh_host_key
# HostKeys for protocol version 2
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_dsa_key
# Lifetime and size of ephemeral version 1 server key
#KeyRegenerationInterval 1h
#ServerKeyBits 768
# Logging
# obsoletes QuietMode and FascistLogging
#SyslogFacility AUTH
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
#PermitRootLogin yes
#StrictModes yes
#MaxAuthTries 6
#RSAAuthentication yes
#PubkeyAuthentication yes
#AuthorizedKeysFile .ssh/authorized_keys
# For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#RhostsRSAAuthentication no
# similar for protocol version 2
#HostbasedAuthentication no
# Change to yes if you don't trust ~/.ssh/known_hosts for
# RhostsRSAAuthentication and HostbasedAuthentication
#IgnoreUserKnownHosts no
# Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# To disable tunneled clear text passwords, change to no here!
#PasswordAuthentication yes
#PermitEmptyPasswords no
# Change to no to disable s/key passwords
#ChallengeResponseAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication mechanism.
# Depending on your PAM configuration, this may bypass the setting of
# PasswordAuthentication, PermitEmptyPasswords, and
# "PermitRootLogin without-password". If you just want the PAM account and
# session checks to run without PAM authentication, then enable this but set
# ChallengeResponseAuthentication=no
#UsePAM no
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding yes
#X11DisplayOffset 10
#X11UseLocalhost yes
#PrintMotd yes
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#UsePrivilegeSeparation yes
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
#UseDNS yes
#PidFile /var/run/sshd.pid
#MaxStartups 10
# no default banner path
#Banner /some/path
# override default of no subsystems
Subsystem sftp /usr/libexec/sftp-server
# AllowUsers to login with NX server
AllowUsers nx looknet
--- final de /etc/ssh/sshd_config ---
--- listagem de arquivos em /etc/ssh ---
root@nxserver:/etc/ssh# ls -laF
total 176
drwxr-xr-x 2 root root 4096 2006-11-29 21:30 ./
drwxr-xr-x 24 root root 4096 2006-11-29 17:30 ../
-rw-r--r-- 1 root root 132839 2005-09-01 11:46 moduli
-rw-r--r-- 1 root root 1292 2005-09-01 11:46 ssh_config
-rw------- 1 root root 1192 2006-11-22 17:06 ssh_host_dsa_key
-rw-r--r-- 1 root root 1115 2006-11-22 17:06 ssh_host_dsa_key.pub
-rw------- 1 root root 976 2006-11-22 17:05 ssh_host_key
-rw-r--r-- 1 root root 640 2006-11-22 17:05 ssh_host_key.pub
-rw------- 1 root root 1675 2006-11-22 17:06 ssh_host_rsa_key
-rw-r--r-- 1 root root 395 2006-11-22 17:06 ssh_host_rsa_key.pub
-rw-r--r-- 1 root root 2944 2006-11-29 21:20 sshd_config
--- fim da listagem ---
Estou utilizando Slackware 10.2, kernel 2.4.31
						 Citação
  Citação
