- MAC + IP com problema
Uso debian 3.1r2, atualiza com upgrade todos os dias... bem é o seguinte minhas politicas de firewall é DROP, e tenho um script que faz o seguinte:
# Libera acesso pelas demais portas.
if [ $TRANS = "sim" ] && [ -x $NOPROXY ] && [ -x $NOARP ]; then
$IPTABLES -A INPUT -p UDP -s $IP -m mac --mac-source $MAC -j udpin_packets
$IPTABLES -A INPUT -p ICMP -s $IP -m mac --mac-source $MAC -j icmp_packets
$IPTABLES -A INPUT -p TCP -s $IP -m mac --mac-source $MAC -m ttl --ttl 32 -j tcp_packets_in
$IPTABLES -A INPUT -p TCP -s $IP -m mac --mac-source $MAC -m ttl --ttl 64 -j tcp_packets_in
$IPTABLES -A INPUT -p TCP -s $IP -m mac --mac-source $MAC -m ttl --ttl 128 -j tcp_packets_in
$IPTABLES -A INPUT -p TCP -s $IP -m mac --mac-source $MAC -m ttl --ttl 255 -j tcp_packets_in
$IPTABLES -A FORWARD -p UDP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -j ACCEPT
$IPTABLES -A FORWARD -p ICMP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -j icmp_packets
$IPTABLES -A FORWARD -p TCP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -m ttl --ttl 31 -j allowed
$IPTABLES -A FORWARD -p TCP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -m ttl --ttl 63 -j allowed
$IPTABLES -A FORWARD -p TCP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -m ttl --ttl 127 -j allowed
$IPTABLES -A FORWARD -p TCP -s $IP -m mac --mac-source $MAC -m limit --limit $BAND_UP/second -m ttl --ttl 254 -j allowed
printf " \033[40;32m [OK] \033[m\n"
elif [ $TRANS = "sim" ] && [ -x $NOPROXY ] && [ ! -x $NOARP ]; then
$IPTABLES -A INPUT -p UDP -s $IP -j udpin_packets
$IPTABLES -A INPUT -p ICMP -s $IP -j icmp_packets
$IPTABLES -A INPUT -p TCP -s $IP -m ttl --ttl 32 -j tcp_packets_in
$IPTABLES -A INPUT -p TCP -s $IP -m ttl --ttl 64 -j tcp_packets_in
$IPTABLES -A INPUT -p TCP -s $IP -m ttl --ttl 128 -j tcp_packets_in
$IPTABLES -A INPUT -p TCP -s $IP -m ttl --ttl 255 -j tcp_packets_in
$IPTABLES -A FORWARD -p UDP -s $IP -m limit --limit $BAND_UP/second -j ACCEPT
$IPTABLES -A FORWARD -p ICMP -s $IP -m limit --limit $BAND_UP/second -j icmp_packets
$IPTABLES -A FORWARD -p TCP -s $IP -m limit --limit $BAND_UP/second -m ttl --ttl 31 -j allowed
$IPTABLES -A FORWARD -p TCP -s $IP -m limit --limit $BAND_UP/second -m ttl --ttl 63 -j allowed
$IPTABLES -A FORWARD -p TCP -s $IP -m limit --limit $BAND_UP/second -m ttl --ttl 127 -j allowed
$IPTABLES -A FORWARD -p TCP -s $IP -m limit --limit $BAND_UP/second -m ttl --ttl 254 -j allowed
elif [ $TRANS = "sim" ] && [ ! -x $NOPROXY ]; then
#$IPTABLES -A PREROUTING -t nat -i eth0 -p TCP -m multiport --dport 3128,80 -j DNAT --to 192.168.30.1:8082
#$IPTABLES -A PREROUTING -t nat -m mac --mac-souce $MAC -p TCP -m multiport --dport 3128,80 -j DNAT --to 192.168.30.1:8082
$IPTABLES -A INPUT -p TCP -m mac --mac-source $MAC -j tcp_packets_in
$IPTABLES -A INPUT -p UDP -m mac --mac-source $MAC -j udpin_packets
$IPTABLES -A INPUT -p ICMP -m mac --mac-source $MAC -j icmp_packets
$IPTABLES -A FORWARD -p ICMP -m mac --mac-source $MAC -j icmp_packets
$IPTABLES -A FORWARD -p TCP -m mac --mac-source $MAC -j allowed
$IPTABLES -A FORWARD -p UDP -m mac --mac-source $MAC -j ACCEPT
else
echo " *** total acesso NEGADO !!! ***"
fi
mas se eu trocar o ip e o mac ja estiver liberado navega normal, posso usar qualquer ip que navego dentro da minha rede claro...
Tenho que carregar quais módulos pra que isso funcione 100%??
Desde ja agradeço....
Kra eu faço assim:
#Aceita requisicoes vindas da eth0 desde que tenham o IP e MAC OK
iptables -A FORWARD -i eth0 -s 172.16.3.1 -m mac --mac-soruce 00:02:3F:CF:25:5B -o eth1 -d 0/0 -j ACCEPT
#Volta dos pacotes
iptables -A FORWARD -o eth0 -m state --state STABLISHED,RELATED -j ACCEPT
#Nega tudo
iptables -A FORWARD -i eth0 -j DROP
#Mascara
iptables -t nat -A POSTROUTING -s 172.16.0.0/16 -o eth1 -j MASQUERADE
Aki ta funfano legal
quais módulos tenho que ativar pra que isso funcione? assim tambem não funcionou...
ola pessoal nem mais uma idéia??
Kra muito estranho pq aki funciona perfeito, qual o erro q da?
não da erro simplesmente troco o ip da maquina do cliente e ele continua navegando... o que esta acontecendo é que se liberar o mac posso colocar qualquer ip que navega...
