Postado originalmente por
gotch
gente!! quem fo mais experiente me diz ai!!!
tinha um server linux numa escola q trabalho!!
eu desconfiava que o antigo adm entrava e fazia umas bagunças!!
instalei o MK!!
so que agora percebi as seguints msg de log
e essas são apenas as da parte da manhã!! sera que tem alguem usando um bruteforce ou algo do tipo?: minha senha e alfa numerica com um nivel de dificuldade alto!!
ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user jack from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user operator from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user operador from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user grafik from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user usuario from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user norma from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user robert from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user roberto from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user bobby from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user cesar from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user daniel from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user jim from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user jimmy from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user lee from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user matt from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user paul from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user peter from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user sean from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user steve from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user steven from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user temp from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user tim from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user tom from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user samba from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user apple from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user master from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user manager from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user root from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user xxx from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user jerry from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user jesus from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user zeus from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user god from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user erica from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user eric from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user alexander from 200.150.229.125 via ssh
[admin@MikroTik] >
echo: system,error,critical login failure for user webuser from 200.150.229.125 via ssh
