e ai galera!
minha duvida é
coloquei uma placa dlink
ela aparece quando mando o note procura rede
e conecta
mas nao navega e nem ve os outros computadores
uso o squid e nat pra compartilhar a internerd aki
liberei o forwar e o input
mas mesmo assim naumm vai
ifconfig
eth0 Link encap:Ethernet HWaddr 00:A1:B0:00:05:0F
inet addr:192.168.1.254 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1272204 errors:0 dropped:0 overruns:0 frame:0
TX packets:1059813 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:787172553 (750.7 MiB) TX bytes:550386302 (524.8 MiB)
Interrupt:5 Base address:0xb000
eth1 Link encap:Ethernet HWaddr 00:A1:B0:00:0A:2A
RX packets:1037050 errors:0 dropped:0 overruns:0 frame:0
TX packets:1127442 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:557938897 (532.0 MiB) TX bytes:755498438 (720.4 MiB)
Interrupt:10 Base address:0xd000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1401 errors:0 dropped:0 overruns:0 frame:0
TX packets:1401 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:155384 (151.7 KiB) TX bytes:155384 (151.7 KiB)
ppp0 Link encap:Point-to-Point Protocol
inet addr:201.48.95.204 P-t-P:200.225.196.80 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1492 Metric:1
RX packets:1026228 errors:0 dropped:0 overruns:0 frame:0
TX packets:1116619 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:534677507 (509.9 MiB) TX bytes:730267170 (696.4 MiB)
wlan0 Link encap:Ethernet HWaddr 00:0F:3D:0E:96:94
inet addr:192.168.1.253 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:576 Metric:1
RX packets:696 errors:0 dropped:0 overruns:0 frame:0
TX packets:6 errors:1 dropped:0 overruns:0 carrier:1
RX bytes:54548 (53.2 KiB) TX bytes:252 (252.0 b)
Interrupt:11 Base address:0xa000
lembrando que naum uso DHCP
e coloquei o ip da wlan0 como gateway no notebook
desdeja obrigado
