Servidor squid consumindo muita memoria, o servidor tem 3 gigas de ram, processador 3.2 Giga, algum tem alguma dica???
http_port 3128 transparent
icp_port 0
cache_mem 64 MB
cache_swap_low 90
cache_swap_high 95
memory_pools off
#maximum_object_size 61440 KB
maximum_object_size_in_memory 100 KB
cache_dir ufs /var/spool/squid 50000 64 256
cache_log cache_log /var/log/squid/cache.log
emulate_httpd_log on
log_fqdn on
ftp_passive on
refresh_pattern . 15 20% 2280
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563
acl Safe_ports port 80 21 443 563 70 210 1025-65535
acl CONNECT method CONNECT
acl sites_liberado url_regex "/etc/squid/acl/sites_liberado" acl deny_geral src "/etc/squid/acl/deny_geral" src "/etc/squid/acl/faz_tudo"
acl sites_banidos url_regex "/etc/squid/acl/sites_banidos" acl palavras_banidos url_regex "/etc/squid/acl/palavras_banidos" # << PALAVRAS BANIDAS
acl sim_ful_net src "/etc/squid/acl/sim_ful_net" # << LISTAS DE IPS QUE USAM O PROXY. OBS 192.168.X
acl NOCACHE url_regex "/etc/squid/acl/direto" \? # << SITES QUE NAO PASSAM PELO PROXY
no_cache deny NOCACHE
http_access allow manager localhost all
memory_pools off
memory_pools_limit 0
http_access deny manager
http_access deny !Safe_ports
http_access allow sites_liberado
http_access deny deny_geral
http_access allow faz_tudo
http_access deny palavras_banidos
http_access deny sites_banidos
http_access allow sim_ful_net all
http_access deny all
icp_access allow all
miss_access allow all
cache_effective_user squid
cache_effective_group squid
cache_mgr proxy@
visible_hostname proxy
