- vmware server no FC6
Olá pessoal, tudo blz ???
estou com um probleminha pra instalr o vmware no Fedora Core 6, testei no ubuntu,
no fedora core 5 e no debian sarge, e instalou sem problemas,
dados do meu sistema:
kernel-devel-2.6.20-1.2948.fc6
kernel-2.6.20-1.2948.fc6
kernel-2.6.18-1.2798.fc6
kernel-headers-2.6.20-1.2948.fc6
Linux suporte-tecnico-02 2.6.20-1.2948.fc6 #1 SMP Fri Apr 27 19:48:40 EDT 2007 i686 i686 i386 GNU/Linux
e recebo o seguinte erro no fim da compilação ...
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: Entrando no diretório `/tmp/vmware-config3/vmmon-only'
make -C /usr/src/kernels/2.6.20-1.2948.fc6-i586/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Entrando no diretório `/usr/src/kernels/2.6.20-1.2948.fc6-i586'
CC [M] /tmp/vmware-config3/vmmon-only/linux/driver.o
In file included from /tmp/vmware-config3/vmmon-only/linux/driver.c:80:
/tmp/vmware-config3/vmmon-only/./include/compat_kernel.h:21: error: expected declaration specifiers or ... before compat_exit
/tmp/vmware-config3/vmmon-only/./include/compat_kernel.h:21: error: expected declaration specifiers or ... before exit_code
/tmp/vmware-config3/vmmon-only/./include/compat_kernel.h:21: warning: type defaults to int in declaration of _syscall1
make[2]: ** [/tmp/vmware-config3/vmmon-only/linux/driver.o] Erro 1
make[1]: ** [_module_/tmp/vmware-config3/vmmon-only] Erro 2
make[1]: Saindo do diretório `/usr/src/kernels/2.6.20-1.2948.fc6-i586'
make: ** [vmmon.ko] Erro 2
make: Saindo do diretório `/tmp/vmware-config3/vmmon-only'
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.
Alguém já passou por isso ???
Falow ...
Tentei usar o vmware-any-any*** que achei na net, agora estou com esse erro ...
cp -f vmmon.ko ./../vmmon.o
make: Saindo do diretório `/tmp/vmware-config15/vmmon-only'
Unable to make a vmmon module that can be loaded in the running kernel:
insmod: error inserting '/tmp/vmware-config15/vmmon.o': -1 Invalid module format
There is probably a slight difference in the kernel configuration between the
set of C header files you specified and your running kernel. You may want to
rebuild a kernel based on that directory, or specify another directory.
Execution aborted.
Help-me ...
Falow ...
Problema com instalacao vmware
bom dia!!!!
eu tive problemas ao instalar o vmware no fc6 e resolvi instalando o pacote kernel-devel.... i686.rpm. ali na saida do erro referencia o kernel.... i586. da uma verificada nisso.
Opa, valeu a dica, resolvi ontem mesmo, não pude postar pois estava sem net,
realmente, o fontes o meu kernel estavam com a arquitetura do processador diferente,
o meu kernel era i686 e os fontes estavam com i585, resolvi instalando os fontes da mesma arquitetura,
Valew ...
