Pessoal,
Utilizo Fedora 6 e configurei Sasacct em uma estação aki porem quando rodo scipt ele cria o link tudo certo via http menos os graficos. Quando vou procurar a imagem .gif pelo caminho que me deu nao existe a imagem, logo nao gera o relatorio. Vou repassar as configs que fiz para possivel ajuda de vcs....segue
1. Arquivos (cimon.plx htmlmaker.plx sasacct.plx sastragraph.plx), coloquei no diretorio /usr/local/bin/
2. Arquivos (sasacct.cgi showgraph.cgi showtraf.cgi), coloquei no /var/www/cgi-bin/
3. Arquivos (cimon.conf sasacct.conf sasacct.users sastragraph.conf), coloquei no /etc/
- Segue configurações do sasacct.conf
# Do not use ":" in your entrys except for a separator
# Accounting Program, currently supported
# are ipfstat,iptables,ipchains and pfctl
F:/sbin/iptables
# Directory for logfiles and rrd files
D:/var/log/sasacct
# Directory to put the graphics.
# Must be in under the web server's root tree
G:/var/www/sasacct/
# Local Entry's
# L:IP: Description
#L:195.34.109.226:Rousse.pm.org
L:192.168.0.191:sastestnet
L:192.168.0.0:net.test.net
#L:195.34.109.227:Marketing Dept.
#L:195.34.109.228:Accounting Dept.
# Remote Entry,
# R:ipmonitored:ftphost:username: pass:acctir
# The example means the following:
# Ftp to 195.34.109.227 with username and
# password, cwd to /var/sasacct/, get file 195.34.109.2
# and store it in what points 'D', in our case /var/sasacct
# on local machine
#R:195.34.109.2:195.34.109.229:username: password:/var/sasacct
#I:IP
# Connect ot host 195.34.226, wich is running sasacct via inetd
# parse the output and collect the information
#I:195.34.109.226
#Locale dir (files with language translation)
E:/root/sasacct-1.0.2/lang/
#language (if not specified defaults to en)
U: pt_BR
Poderia ser problemas dos arquivos .cgi???
Obrigado!!!!!
Citação
