Pessoal, estou testando a ferramenta cacti, já uso o mrtg , e gostaria da força de vcs para
desvendar esse mistério, vou postar abaixo o err ocorrido, e os passos que segui na configuração.
ao acessar a url: http://meuip/cacti , me retorna o seguinte:
Error
You have created a new database, but have not yet imported the 'cacti.sql' file. At the command line, execute the following to continue:
mysql -u cactiuser -p cacti < cacti.sql
This error may also be generated if the cacti database user does not have correct permissions on the cacti database. Please ensure that the cacti database user has the ability to SELECT, INSERT, DELETE, UPDATE, CREATE, ALTER, DROP, INDEX on the cacti database.
já fiz isso que foi solicitado umas dez veses, já tentei mudar os privilégios pelo PhpMyadmin, e nada, o que deve estar faltando ... ???
Extract the distribution tarball.
shell> tar xzvf cacti-version.tar.gz
Create the MySQL database:
shell> mysqladmin --user=root create cacti
Import the default cacti database:
shell> mysql cacti < cacti.sql
Optional: Create a MySQL username and password for Cacti.
shell> mysql --user=root mysql
mysql> GRANT ALL ON cacti.* TO cactiuser@localhost IDENTIFIED BY 'somepassword';
mysql> flush privileges;
Edit include/config.php and specify the MySQL user, password and database for your Cacti configuration.
$database_default = "cacti";
$database_hostname = "localhost";
$database_username = "cactiuser";
$database_password = "cacti";
Set the appropriate permissions on cacti's directories for graph/log generation. You should execute these commands from inside cacti's directory to change the permissions.
shell> chown -R cactiuser rra/ log/
(Enter a valid username for cactiuser, this user will also be used in the next step for data gathering.)
Add a line to your /etc/crontab file similar to:
*/5 * * * * cactiuser php /var/www/html/cacti/poller.php > /dev/null 2>&1
Falow ...
Citação
