-  Kernel 2.4.21
 Kernel 2.4.21
							Nome: kernel-2.4.21.0.25mdk
Versão: 1-1mdk
Tamanho: 17665 KB
Resumo: The Linux kernel (the core of the Linux operating system).
Descrição: The kernel package contains the Linux kernel (vmlinuz), the core of your Mandrake Linux operating system.  The kernel handles the basic functions of the operating system:  memory allocation, process allocation, device input and output, etc.
Nome: kernel-BOOT-2.4.21.0.25mdk
Versão: 1-1mdk
Tamanho: 6568 KB
Resumo: The version of the Linux kernel used on installation boot disks.
Descrição: This package includes a trimmed down version of the Linux kernel. This kernel is used on the installation boot disks only and should not be used for an installed system, as many features in this kernel are turned off because of the size constraints.
Nome: kernel-doc
Versão: 2.4.21-0.25mdk
Tamanho: 5378 KB
Resumo: Various documentation bits found in the kernel source.
Descrição: This package contains documentation files form the kernel source. Various bits of information about the Linux kernel and the device drivers shipped with it are documented in these files. You also might want install this package if you need a reference to the options that can be passed to Linux kernel modules at load time.
Nome: kernel-enterprise-2.4.21.0.25mdk
Versão: 1-1mdk
Tamanho: 17599 KB
Resumo: The Linux Kernel compiled with options for Enterprise server usage.
Descrição: This package includes a kernel that has appropriate configuration options enabled for the typical large enterprise server.  This includes SMP support for multiple processor machines, support for large memory configurations and other appropriate items.
Nome: kernel-secure-2.4.21.0.25mdk
Versão: 1-1mdk
Tamanho: 18068 KB
Resumo: The Linux Kernel compiled for SECURE machines.
Descrição: This package includes a SECURE version of the Linux 2.4.21 kernel. This package add options for kernel that make it more secure for servers and such. See :
http://grsecurity.net/features.htm
for list of features we have included.
Nome: kernel-smp-2.4.21.0.25mdk
Versão: 1-1mdk
Tamanho: 18002 KB
Resumo: The Linux Kernel compiled for SMP machines.
Descrição: This package includes a SMP version of the Linux 2.4.21 kernel. It is required only on machines with two or more CPUs, although it should work fine on single-CPU boxes.
Nome: kernel-source
Tamanho: 158399 KB
Resumo: The source code for the Linux kernel.
Descrição: The kernel-source package contains the source code files for the Linux kernel. These source files are needed to build most C programs, since they depend on the constants defined in the source code. The source files can also be used to build a custom kernel that is better tuned to your particular hardware, if you are so inclined (and you know what you´re doing).
Será que alguém poderia me dizer para que serve esses pacotes? Eu utilizo o Mandrake Linux 9.1, se alguém quiser traduzir... melhor ainda.
 Kernel 2.4.21
							Bom nao eh dificil isso ... apenas tenha em mente que voce prescisa do kernel , kernel-* , onde * eh boot, enterprise entre outros voce nao prescisa para sua maquina maquina desktop
BOOT - usado em disketes de boot
doc - documentacao (ohhh)
enterprise - maquinas com > 4gb ram
smp - 2 proc ou mais
 Kernel 2.4.21
							E ai mistymst,
Para uma maquina desktop, do que eu precisaria então dentre todos esses ai?
Eu não entendi muito bem sober esse smp, será que poderia me explicar também sobre o secure? Acho que você esqueceu.
 Kernel 2.4.21
							geek,
o pacote secure adiciona ao kernel mais opções de segurança às suas ja existentes, tipow... naum conheco mto bem quais seriam essas opções, e o link q ele indica soh pra ajudar esta quebrado hehe
o smp eh um outro kernel q eh usado quando vc tem uma placa q possua dois processadores, esse kernel possui uma estrutura diferente, uma vez instalado ele identifica as cpus e quebra o processamento entre os dois processadores existentes (mais ou menos)
smp eh um topico interessante, usado com frequencia em servidores, acho q vale ateh uma pesquisa no google
t+ kra  <IMG SRC="images/forum/icons/icon_wink.gif">  <IMG SRC="images/forum/icons/icon_wink.gif">  <IMG SRC="images/forum/icons/icon_wink.gif">
 Kernel 2.4.21
							demiurgo,
E esse pacote kernel-BOOT-2.4.21.0.25mdk serve para que?
Diz rapido ae, porque já estou fazendo o download os pacotes para instala-los.
 Kernel 2.4.21
							Secure eh apenas o kernel compilado com o patch da grsecurity, ou seja, um harderned kernel ... em outras palavras, um kernel mas seguro, proprio para servidor, que nao vale a pena rodar em casa.
o BOOT eu jah expliquei.
Como eu havia dito antes... para uma maquina desktop voce so prescisa do kernel.
Versão: 1-1mdk
Tamanho: 17665 KB
 Kernel 2.4.21
							mistymst,
Mas o pacote kernel-BOOT-2.4.21.0.25mdk não é para usar disketes, principalmente diskete de boot?
 Kernel 2.4.21
							Pelo visto vc nao entendeu... suponho que voce nao sabe ingles nao eh?
Versão: 1-1mdk
Tamanho: 6568 KB
"Esse pacote inclui uma versao reduzida do kernel do linux. Este kernel eh usado apenas na instalacao com disketes de boot e nao DEVERA SER UTILIZADO para um sistema JAH INSTALADO, pois muitas funcoes nesse kernel estao desativiadas devido ao seu tamanho."
Espero que tenha ficado claro o q o pacote kernel-BOOT faz e qual sua serventia.
 Kernel 2.4.21
							Valeu pela ajuda mistymst
 Kernel 2.4.21
							mistymst,
Se eu não tenho o pacote: kernel-2.4.21.0.25mdk-1-1mdk.i586.rpm instalado na maquina, eu instalo ele através do comando rpm -i kernel-2.4.21.0.25mdk-1-1mdk.i586.rpm ou através do comando: rpm -Uvh kernel-2.4.21.0.25mdk-1-1mdk.i586.rpm?
 Kernel 2.4.21
							Na boa, rpm funciona assim
-i = install
-U = upgrade
-v = verbose
-h = hash
O certo seria voce instalar o kernel com rpm -ivh mas isso nao funciona assim.. voce sempre instala o kernel com rpm -Uvh, pois eh sempre um upgrade, de modo a nao apagar o kernel antigo... pois alguma coisa der errada voce ainda tem como bootar o sistema no kernel antigo.
 Kernel 2.4.21
							valha-me santíssima trindade!
