Postado originalmente por
faieppi
Olá amigo, eu fiz isso, veja a imagem e os scripts abaixo
http://img292.imageshack.us/img292/8256/mk4ve4.th.jpg
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.100.254 scope=255 target-scope=10 \ comment="" disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.200.254 scope=255 target-scope=10 \
routing-mark=link2 comment="Pacotes marcados redirecionados para o link2" \
disabled=no
/ ip firewall mangle
add chain=prerouting protocol=tcp dst-port=80 action=mark-routing new-routing-mark=link2 passthrough=yes \
comment="Portas 80 e 443 direcionada para o link2" disabled=no
add chain=prerouting protocol=tcp dst-port=443 action=mark-routing new-routing-mark=link2 passthrough=yes \
add chain=prerouting routing-mark=link2 action=mark-packet new-packet-mark=link2 passthrough=yes \
comment="Pacotes marcados das portas 80 e 443 e outras com o link2" disabled=no
add chain=prerouting protocol=tcp dst-port=21 action=mark-routing new-routing-mark=link2 passthrough=yes \
comment="Outras portas redirecionada para o link2" disabled=no
add chain=prerouting protocol=tcp dst-port=22 action=mark-routing new-routing-mark=link2 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=23 action=mark-routing new-routing-mark=link2 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=25 action=mark-routing new-routing-mark=link2 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=53 action=mark-routing new-routing-mark=link2 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=110 action=mark-routing new-routing-mark=link2 passthrough=yes \
Eu deixei o link 1 como padrão e o link2 eu direcionei as portas 80, 443 e etc, acontece q qdo o link1 ou seja, o padrão ñ tem trafego o link2 funciona normal, navega, abre sites de banco, td blz, mas qdo ligo o e-mule por ex q começa a baixar arquivos pelo link1 padrão o link2 q está a porta 80 e 443 começa a parar, dá pausas enormes, tipo, vc clica e depois de 10 segundo q abre e as vezes nem abre, dá erro de página, o q está acontecendo? será q falta algo? Valeuuu
