Pessoal estou com um problema aqui, a radio uol na conectar. Minha configuração está basica, só tem o NAT padrão. O que será que tenho que fazer?
Espero que esse meu problema possa ajuda aos outros.
Abraço
Abraço
ip firewall filter
add chain=virus protocol=tcp dst-port=445 action=drop comment="bloqueio de \
VIRUS conhecidos" disabled=no
add chain=virus protocol=udp dst-port=445 action=drop comment="" disabled=no
add chain=virus protocol=tcp dst-port=593 action=drop comment="" disabled=no
add chain=virus protocol=tcp dst-port=1080 action=drop comment="" disabled=no
add chain=virus protocol=tcp dst-port=1363 action=drop comment="" disabled=no
add chain=virus protocol=tcp dst-port=1364 action=drop comment="" disabled=no
add chain=virus protocol=tcp dst-port=1373 action=drop comment="" disabled=no
add chain=virus protocol=tcp dst-port=1377 action=drop comment="" disabled=no
add chain=virus protocol=tcp dst-port=1368 action=drop comment="" disabled=no
add chain=virus protocol=tcp dst-port=1433-1434 action=drop comment="" \
disabled=no
add chain=virus protocol=tcp dst-port=1024-1030 action=drop comment="" \
disabled=no
add chain=virus protocol=tcp dst-port=1214 action=drop comment="" disabled=no
add chain=virus protocol=tcp dst-port=135-139 action=drop comment="Drop \
Blaster Worm" disabled=no
add chain=virus protocol=udp dst-port=135-139 action=drop comment="Drop \
Messenger Worm" disabled=no
add chain=virus protocol=tcp dst-port=445 action=drop comment="Drop Blaster \
Worm" disabled=no
add chain=virus protocol=udp dst-port=445 action=drop comment="Drop Blaster \
Worm" disabled=no
add chain=virus protocol=tcp dst-port=593 action=drop comment="________" \
disabled=no
add chain=virus protocol=tcp dst-port=1024-1030 action=drop comment="________" \
disabled=no
add chain=virus protocol=tcp dst-port=1080 action=drop comment="Drop MyDoom" \
disabled=no
add chain=virus protocol=tcp dst-port=1214 action=drop comment="________" \
disabled=no
add chain=virus protocol=tcp dst-port=1363 action=drop comment="ndm requester" \
disabled=no
add chain=virus protocol=tcp dst-port=1364 action=drop comment="ndm server" \
disabled=no
add chain=virus protocol=tcp dst-port=1368 action=drop comment="screen cast" \
disabled=no
add chain=virus protocol=tcp dst-port=1373 action=drop comment="hromgrafx" \
disabled=no
add chain=virus protocol=tcp dst-port=1377 action=drop comment="cichlid" \
disabled=no
add chain=virus protocol=tcp dst-port=1433-1434 action=drop comment="Worm" \
disabled=no
add chain=virus protocol=tcp dst-port=2745 action=drop comment="Bagle Virus" \
disabled=no
add chain=virus protocol=tcp dst-port=2283 action=drop comment="Drop Dumaru.Y" \
disabled=no
add chain=virus protocol=tcp dst-port=2535 action=drop comment="Drop Beagle" \
disabled=no
add chain=virus protocol=tcp dst-port=2745 action=drop comment="Drop \
Beagle.C-K" disabled=no
add chain=virus protocol=tcp dst-port=3127-3128 action=drop comment="Drop \
porta proxy" disabled=no
add chain=virus protocol=tcp dst-port=3410 action=drop comment="Drop Backdoor \
OptixPro" disabled=no
add chain=virus protocol=tcp dst-port=4444 action=drop comment="Worm" \
disabled=no
add chain=virus protocol=udp dst-port=4444 action=drop comment="Worm" \
disabled=no
add chain=virus protocol=tcp dst-port=5554 action=drop comment="Drop Sasser" \
disabled=no
add chain=virus protocol=tcp dst-port=8866 action=drop comment="Drop Beagle.B" \
disabled=no
add chain=virus protocol=tcp dst-port=9898 action=drop comment="Drop \
Dabber.A-B" disabled=no
add chain=virus protocol=tcp dst-port=10000 action=drop comment="Drop \
Dumaru.Y" disabled=no
add chain=virus protocol=tcp dst-port=10080 action=drop comment="Drop \
MyDoom.B" disabled=no
add chain=virus protocol=tcp dst-port=12345 action=drop comment="Drop NetBus" \
disabled=no
add chain=virus protocol=tcp dst-port=17300 action=drop comment="Drop Kuang2" \
disabled=no
add chain=virus protocol=tcp dst-port=27374 action=drop comment="Drop \
SubSeven" disabled=no
add chain=virus protocol=tcp dst-port=65506 action=drop comment="Drop PhatBot, \
Agobot, Gaobot" disabled=no
Estou usando essas regra no filter, agora o do nat estou usando só a padrão de liberação da net e a do web-proxy
caraaa nao ea ai nao
ne nessa parte do firewall nao
/ip firewall nat
ai tu coloca
/ ip firewall nat
add chain=pre-hotspot dst-address=200.221.0.0/16 action=accept comment="Radio uol Hotspot" disabled=no
add chain=dstnat dst-address=200.221.0.0/16 action=accept comment="Radio Uol Bridger" disabled=no
essas regras ai
a primeira e pra hotspot
a segunda sem ser por hotspot
coloca as duas
essas regras tem q ta emcima da regra q faz o mascaramento
o nat
exemplo
add chain=srcnat out-interface=link action=masquerade comment="NAT" disabled=no
essa regra faz o nat
coloca
desse jeito
/ ip firewall nat
caro amigo eu tb tenho esses problemas de radio uol, se desabilito o webproxy funcina, ja coloquei as regras citadas acima mas nada de funcionar! não uso hostpost. gostaria que alguem que ja passou por esse problema me ajudasse, uso o mk 2.9.27
atenciosamente
marcos
caro amigo deu certo a radio uol esta funcionando beleza! mas tive de remover o webproxy refaser tudo ae deu certo! não sei se tem alguma coisa haver mas esta funcionando!
agora precisava se pudesse me ajudar na caixa econômica em conectividade social. vc tem alguma regra para isso?
mas grato pela ajuda na radio uol!
atenciosamente
marcos
oi
cara e a mesma regra
mais tu coloca o ip da conectividade
do lugar do ip q tem da uol
olha ai qualquer coisa me fala
ola amigo gostaria de saber se alguem de vcs ja usaram redirecionamento de paginas no mkt, tipo assim uma pagia hospedada em um micro na rede ae redireciona para manutenção! entenderam se não retorne que eu falo mais um pouco!
muito obrigado
marcos
Cara Não deu certo aqui, coloquei a regra antes do redirecionamento do proxy e testei antes do nat e nao foi.
