- Hotspot sem funcionar
Configurei o hotspot mas não funciona , alguém pode me ajudar?
Navavega normalmente sem o hotspot(desabilitado) e controla muito bem com as queues.
Configs:
/ ip address
add address=200.168.0.1/24 network=200.168.0.0 broadcast=200.168.0.255 interface=ether2 \
comment="Clientes" disabled=no
add address=192.168.1.3/24 network=192.168.1.0 broadcast=192.168.1.255 interface=ether1 \
comment="Link" disabled=no
ip hotspot
add name="hs-ether2" interface=ether2 address-pool=hs-pool-2 profile=hsprof1 \
idle-timeout=5m keepalive-timeout=none addresses-per-mac=2 disabled=no
/ ip hotspot service-port
set ftp ports=21 disabled=no
/ ip hotspot profile
set default name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot \
rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=cookie,http-chap \
http-cookie-lifetime=3d split-user-domain=no use-radius=no
add name="hsprof3" hotspot-address=200.168.0.1 dns-name="SunNet" html-directory=hotspot \
rate-limit="64k/128k" http-proxy=200.168.0.2:3128 smtp-server=255.255.255.0 \
login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
add name="hsprof1" hotspot-address=200.168.0.1 dns-name="SunNet" html-directory=hotspot \
/ ip hotspot user
add server=hs-ether2 name="teste" password="teste" address=200.168.0.5 \
mac-address=00:07:95:5D
C:B2 profile=128/64 comment="" disabled=no
/ ip hotspot user profile
set 128/64 name="128/64" address-pool=hs-pool-2 idle-timeout=15m keepalive-timeout=3m \
status-autorefresh=12h shared-users=1 rate-limit="64k/128k" transparent-proxy=yes \
open-status-page=always advertise=no
/ ip dns
set primary-dns=200.165.132.154 secondary-dns=200.165.132.147 allow-remote-requests=no \
cache-size=2048KiB cache-max-ttl=1w
/ ip dns static
add name="Velox" address=192.168.1.1 ttl=1d
/ ip pool
add name="dhcp-pool-1" ranges=192.168.1.2-192.168.1.254
add name="hs-pool-2" ranges=200.168.0.2-200.168.0.254
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.1.1 scope=255 target-scope=10 comment="" \
disabled=no
/ ip firewall nat
add chain=srcnat out-interface=ether1 action=masquerade comment="" disabled=no
add chain=srcnat src-address=200.168.0.0/24 action=masquerade comment="masquerade hotspot \
network" disabled=no
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=2m tcp-syn-received-timeout=1m \
tcp-established-timeout=5d tcp-fin-wait-timeout=2m tcp-close-wait-timeout=1m \
tcp-last-ack-timeout=30s tcp-time-wait-timeout=2m tcp-close-timeout=10s \
udp-timeout=30s udp-stream-timeout=3m icmp-timeout=30s generic-timeout=10m
/ ip firewall filter
/ ip firewall service-port
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set mms disabled=no
set gre disabled=yes
set pptp disabled=yes
/ ip dhcp-server
add name="dhcp1" interface=ether2 lease-time=3d address-pool=dhcp-pool-1 \
bootp-support=static disabled=no
/ ip dhcp-server config
set store-leases-disk=5m
/ ip dhcp-server network
add address=192.168.1.0/24 gateway=192.168.1.1 dns-server=200.165.132.154,200.165.132.147 \
comment="added by setup"
add address=200.168.0.0/24 gateway=200.168.0.1 comment="hotspot network"
/ queue type
set default name="default" kind=pfifo pfifo-limit=50
set ethernet-default name="ethernet-default" kind=pfifo pfifo-limit=50
set wireless-default name="wireless-default" kind=sfq sfq-perturb=5 sfq-allot=1514
set synchronous-default name="synchronous-default" kind=red red-limit=60 \
red-min-threshold=10 red-max-threshold=50 red-burst=20 red-avg-packet=1000
set hotspot-default name="hotspot-default" kind=sfq sfq-perturb=5 sfq-allot=1514
/ queue simple
add name="001 Loja" target-addresses=200.168.0.5/32 dst-address=0.0.0.0/0 interface=ether2 \
parent=none priority=8 queue=default/default limit-at=64000/128000 \
max-limit=64000/128000 total-queue=default disabled=no
add name="002 Casa" target-addresses=200.168.0.6/32 dst-address=0.0.0.0/0 interface=ether2 \
Olá Marcio!
Não é a interface que está errada?
ip hotspot
no lugar de ether2 não é ether1?
Falow!
tentei com a ether1 e nada, a ether1 é que entra o link e a ether2 é a que vai para os PCs clientes
valeu pela força
mais alguem p dar uma força?
chef..
seta essa parte aqui:
DNS Name: auth.seuprovedor.com.br
comando corrigido:
set default name="default" hotspot-address=0.0.0.0 dns-name="auth.ispwireless.com.br" html-directory=hotspot \
isso vai fazer criar uma tag no DNS , que vai marcar o seu ip como um dns, daeh toda vez quem alguem for navegar vai redirecionar pra esse auth.ispwireless.com.br e via fazer pedir tela de Login ;]
o resto é como você,
lembrando vC tem que ativar o hotspot na placa pra cliente.
luizbe, valeu pela força, está funcionando aqui.
Muito obrigado
Marcio
para quem manja de hotsport - mk
Camaradas sou novo a qui, e gostaria de saber se no hotspot do mk tem como particionar o tempo de uso, pelo sequinte, quero implantar em um hotel e o proprietaro quer que quando o clinete achar a rede, pessa a portaria um loguin e senha para uso, mais que o tempo nâo seja corrido e sim que ele possa desconectar e conectar depois mais que o contador voute do tempo parado e nao tenlha terminado, porque estava corrido, gostari de uma ajuda camaradas, Valeu.
