Postado originalmente por
diegovilela01
oi amigos estou o seguinte problema, meu servidor mikrotik com hotspot ate ai tudo blz, tive q mudar meu ap de uma torre q tem varios clientes, entao montei um routerboard, 254 ram, hd 20, proc 2.0 amd, e cartao Mini PCI Atheros 6th com adaptador, antena omni 15dbi, entao a navegacao dos clientes esta muito lenta.
Segue minhas configuracoes:
0 R name="wlan1" mtu=1500 mac-address=00:02:6F:46:85:4F arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=""
mode=ap-bridge ssid="" area="" frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2437 band=2.4ghz-b
scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power=26 tx-power-mode=card-rates noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
