Meu Squid.conf..
hierarchy_stoplist cgi-bin ?
no_cache deny QUERY
auth_param basic children 5
auth_param basic realm Squid proxy-caching web server
auth_param basic credentialsttl 2 hours
refresh_pattern . 0 20% 4320
#CACHE
cache_mem 64 MB
cache_dir ufs /usr/local/squid/cache/ 7000 16 256
cache_dir diskd /usr/local/squid/cache/ 256 16 256 Q1=64 Q2=72
maximum_object_size 2048 KB
emulate_httpd_log on
cache_mgr [email protected]
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl CONNECT method CONNECT
# SECAO ACL REDE INTERNA
acl rede_interna src 192.168.1.0/24
http_access allow rede_interna
# SECAO DE BLOCK
acl pro_ip src "/usr/local/squid/block/pro_ip"
acl pro_url url_regex "/usr/local/squid/block/pro_url"
# SECAO HTTP_ACCESS
http_access deny manager
http_access deny !Safe_ports
http_access allow localhost
http_access deny all
http_reply_access allow all
http_access deny pro_ip
http_access deny pro_url
icp_access allow all
coredump_dir /var/spool/squid
httpd_accel_port 80
httpd_accel_host virtual
httpd_accel_with_proxy on
ie_refresh on
