PRECISO DE UM HELP, GENTE:
PRECISO DE UMA DICA DE UM BOM PROGRAMA DE ACESSO A TERMINAL,
TIPO O COM 7.6 (DA WINSOFT), E TIPO O HIPERTERMINAL DO RUINDOWS...
ESSE PROGRAMA PODERIA SER ATEH COM BASE NO RUINDWS, MAS A MINHA IDEIA INICIAL EH RODA-LO APARTIR DO LINUX.
O PROBLEMA EH O SEGUINTE:
TENHO UM SISTEMA UNIX (QNX.2) QUE DEVERAH SER ACESSADO VIA INTERNET, PARA ISSO SERAH USADO , OU O TERM. SERVER. DO RUINW2003, OU UM ACESSO DE TERMINAL (VNC,LTS,XWIN) DO LINUX E APARTIR DO SISTEMA ACESSADO SERAH UTILIZADO **ESSE PROGRAMA DE TERMINAL**
O CASO EH QUE TODOS OS PROGRAMAS (PADRAO RUINDOWS) DEIXAM A TELA MUITO PEQUENA, E NAO TEM INTERFACE CONFIGURAVEL PARA TECLAS DE FUNCAO , (MODO DE ACESSO VT100), ETC...
ATEH UM PROGRAMINHA (BEM COMPLETO) VERSAO DOS, RESOLVERIA O CASO .. (SE BEM QUE ELIMINARIA A POSSIBILIDADE DE RODAR VNC, POIS ESSE TEM PROBLEMAS COM TELAS DOS TOTALMENTE ABERTAS)...
OBRIGADO A TODOS, DESDE JAH...
