-  C
 C
							eu tenho esse script em C
 #include <stdio.h>
  #include <stdlib.h>
  #include <sys/io.h>
  #include <unistd.h>
  typedef char byte;
   Port addresses (´dmesg | grep parport0´
   0x3bc = lp0       0x378 = lp1       0x278 = lp2
  #define BASEPORT 0x378
  #define DATA BASEPORT+0
  #define STATUS BASEPORT+1
  #define CONTROL BASEPORT+2
   Function headers
  byte isbitset (byte val, byte bit);
  byte setbit (byte val, byte bit);
   And... here it is... The main part...
  int main (int argc, char *argv[])
   byte signal=setbit(0, 0);
   byte data=0, status=0, control=0;
   if (argc == 1)
    printf("PPSW - Parallel Port Switcher\n"<IMG SRC="images/forum/icons/icon_wink.gif">;
    printf("by Herbert G. Fischer 2001\n"<IMG SRC="images/forum/icons/icon_wink.gif">;
    printf("GPL license (http://www.gnu.org/licenses/gpl.html)\n\n"<IMG SRC="images/forum/icons/icon_wink.gif">;
    printf("ppsw [cmd] &\n"<IMG SRC="images/forum/icons/icon_wink.gif">;
    printf("[cmd] - full path to application to run\n\n"<IMG SRC="images/forum/icons/icon_wink.gif">;
    exit(1);
   // get permissions to use I/O ports
   if (ioperm(BASEPORT, 3, 1))
    perror("ioperm"<IMG SRC="images/forum/icons/icon_wink.gif">;
    exit(1);
   while (1)
    // send a bit to port
    outb(data, DATA);
    // get response from input
    status = inb(STATUS);
    if (isbitset(status, 4))
     // run the specified program
     if (!system(argv[1]))
      exit(1);
     else
      exit(0);
    // wait 50ms to loop again
    usleep(50000);
   // free I/O permissions
   if (ioperm(BASEPORT, 3, 0))
    exit(1);
   return 0;
  // is the ´bit´ set on ´val´?
   byte bitpos[] = { 0x1, 0x2, 0x4, 0x8, 0x10, 0x20, 0x40, 0x80 };
   return (val & bitpos[bit]);
mas qdo vou compilar
gcc -02 ppsw.c -o ppsw
ele da esse erro:/tmp/ccf0Egmj.o: In function `main´:
/tmp/ccf0Egmj.o(.text+0x14): undefined reference to `setbit´
collect2: ld returned 1 exit status
 C
							<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
 #include <stdio.h>
  #include <stdlib.h>
  #include <sys/io.h>
  #include <unistd.h>
  typedef char byte;
   Function headers
   if (argc == 1)
    printf("PPSW - Parallel Port Switcher\n"-);
    printf("by Herbert G. Fischer 2001\n"-);
    printf("GPL license (http://www.gnu.org/licenses/gpl.html)\n\n"-);
    printf("ppsw [cmd] &\n"-);
    printf("[cmd] - full path to application to run\n\n"-);
    exit(1);
    perror("ioperm"-);
    exit(1);
   while (1)
    outb(data, DATA);
      exit(1);
     else
      exit(0);
    usleep(50000);
    perror("ioperm"-);
    exit(1);
   return 0;
O Código correto para efetuar esta tarfa está logo abaixo o que aconteceu é que a variavel foi declarada e não foi executada no final do programa. Também estava faltando executar uma ação com ; (ponto e vírgula. Executado com a ajuda de Jairo (fera em programação em C) e testado do por Marcelo Falcão.
#include <stdio.h>
#include <stdlib.h>
#include <sys/io.h>
#include <unistd.h>
typedef char byte;
 *  Port addresses (´dmesg | grep parport0´
 *   0x3bc = lp0       0x378 = lp1       0x278 = lp2
 *  Function headers
 *  And... here it is... The main part...
int main (int argc, char* argv[])
        byte signal=setbit(0,0);
        if (argc == 1)
                printf("PPSW - Parallel Port Switcher\n");
                printf("by Herbert G. Fischer 2001\n");
                printf("GPL license (http://www.gnu.org/licenses/gpl.html)\n\n");
                printf("ppsw [cmd] &\n");
                printf("[cmd] - full path to application to run\n\n");
                exit(1);
        perror("ioperm");
        exit(1);
        while (1)
                outb(data, DATA);
                                exit(1);
                        else
                                exit(0);
                usleep(50000);
                perror("ioperm");
                exit(1);
        return 0;
//is the ´bit´ set on ´val´?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
