Boa noite qual a diferença destes paineis:
qual a melhor.
- W. ANTENA HYP 14DBI SETORIAL 2.4GHZ HG2414SP-120
Electrical Specifications
Frequency
2400 - 2500 MHz
Gain
14 dBi
Polarization
Vertical
Horizontal Beam Width
120°
Vertical Beam Width
15°
Impedance
50 Ohm
VSWR
< 1.5:1 avg.
Front to Back Ratio
> 21 dB
Max. Input Power
300 Watts
Lightning Protection
DC Ground
Connector Integral N-Female
Mechanical Specifications
Weight
4.4 lbs. (2 kg)
Dimensions
20 x 7 x 3.5 inch
(500 x 180 x 90 mm)
Radome Material
UV-inhibited Plastic
Mounting
2 inch (50 mm) dia. mast max.
Operating Temperature -40° C to to 85° C
(-40° F to 185° F)
Rated Wind
>130 MPH (210 Km/h)
- W. ANTENA HYP 14DBI SETORIAL 90 grau 2.4GHZ HG2414HSP-090
Antena usada para a faixa de freqüência de 2.4 GHz possui um ganho de 14 dBi e irradia o sinal com um lóbulo de 90 graus com polarização horizontal.
- Frequency 2400 - 2500 MHz
- Gain 14 dBi
- Polarization Horizontal
- Horizontal Beam Width 90°
- Vertical Beam Width 20°
- Impedance 50 Ohm
- VSWR < 1.5:1 avg.
- Front to Back Ratio > 21 dB
- Max. Input Power 300 Watts
- Lightning Protection DC Ground
- Connector Integral N-Female
- Weight 4.4 lbs. (2 kg)
- Dimensions (500 x 180 x 90 mm)
- Radome Material UV-inhibited Plastic
- Mounting 2 inch (50 mm) dia. mast max.
- Operating Temperature -40° C to to 85° C (-40° F to 185° F)
- Rated Wind >130 MPH (210 Km/h)
