- licq pifou
licq pifou
Galera help, meu licq deu pau e ja nao sei oq fazer...ja reinstalei e continua dando o mesmo pau.
OQ ACONTECE???
Licq Segmentation Violation Detected.
Backtrace:
/usr/lib/licq/licq-bin(licq_handle_sigsegv+0x85) [0x80a2405]
/lib/i686/libpthread.so.0 [0x40125f05]
/usr/lib/licq/licq-bin [0x42029188]
/usr/X11R6/lib/X11/locale/common/ximcp.so.2 [0x41961d7a]
/usr/X11R6/lib/X11/locale/common/ximcp.so.2(_XimLocalOpenIM+0xbd) [0x41961e6d]
/usr/X11R6/lib/X11/locale/common/ximcp.so.2(_XimOpenIM+0x14c) [0x4196131c]
/usr/X11R6/lib/libX11.so.6 [0x405adb13]
/usr/X11R6/lib/X11/locale/common/ximcp.so.2(_XimRegisterIMInstantiateCallback+0xd5) [0x41960b55]
/usr/X11R6/lib/libX11.so.6 [0x405adc1b]
/usr/X11R6/lib/libX11.so.6(XRegisterIMInstantiateCallback+0x47) [0x40590907]
/usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3(qt_init_internal__FPiPPcP9_XDisplayUlUl+0x1757) [0x40791197]
/usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3(qt_init__FPiPPcQ212QApplication4Type+0x25) [0x407918d5]
/usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3(construct__12QApplicationRiPPcQ212QApplication4Type+0x63) [0x407e6a23]
/usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3(__12QApplicationRiPPcb+0x5a) [0x407e68ca]
/usr/lib/libkdecore-gcc2.96.so.4(__12KApplicationRiPPcRC8QCStringbT4+0x2b) [0x40e29c9b]
/usr/lib/licq/licq_kde-gui.so(__8CLicqGuiiPPc+0x4<IMG SRC="images/forum/icons/icon_cool.gif"> [0x402319a8]
/usr/lib/licq/licq_kde-gui.so(LP_Main+0x3d) [0x4023095d]
/usr/lib/licq/licq_kde-gui.so(LP_Main_tep+0x1b) [0x4023063f]
/lib/i686/libpthread.so.0 [0x40122faf]
/usr/lib/licq/licq-bin(__clone+0x3a) [0x420e790a]
Attempting to generate core file.
licq pifou
olhando assim não da pra saber o q aconteceu, e so reinstalando não funciona pq as bibliotecas já estarão configuradas.
Tente remover as bibliotecas dele e reinsta-le depois, talvez isto possa ajudar...
<IMG SRC="images/forum/icons/icon_wink.gif">
licq pifou
nao sei <IMG SRC="images/forum/icons/icon_smile.gif"> assim eh dificil de dizer... tente reinstalar o licq POR completo (inclusive as libs) como foi dito anteriormente... nao da para te dizer pq da esse pau <IMG SRC="images/forum/icons/icon_smile.gif"> tudo q eu vejo sao um bando de endereco hexadecimais nas bibliotecas q estavam na memoria ... <IMG SRC="images/forum/icons/icon_razz.gif">
licq pifou
E pra tirar estas bibliotecas como faco??? E soh remover???
licq pifou
E ae galera ninguem tem uma luz ae?!?!?!?
Poxa estou ficando loko ja nao consigo rodar nem a pau....reinstalei umas 20x e nada. O Problema eh q c eu remover todas as bibliotecas vai dar pau em tudo pois tem algumas q nao sao do licq.
<IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif">
licq pifou
pq vc nao usa outro cliente tipo, o gaim,kicq, etc....
o que tem mais eh cliente de icq.
teh mais
licq pifou
Faça como eu...
Use o mICQ.
E leve, rapido e muito bom...
Falows.
