host1# vi proftpd.conf
# For more informations about Proftpd configuration
# look at : [URL="http://www.proftpd.org/"]The ProFTPD Project: Home[/URL]
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use. It establishes a single server
# and a single anonymous login. It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName "ProFTPD Default Installation"
ServerType standalone
DefaultServer on
ScoreboardFile /var/run/proftpd.scoreboard
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd).
MaxInstances 30
CommandBufferSize 512
# Set the user and group under which the server will run.
User nobody
Group nogroup
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
DefaultRoot ~
# Normally, we want files to be overwriteable.
AllowOverwrite on
# Bar use of SITE CHMOD by default
#<Limit SITE_CHMOD>
# DenyAll
#</Limit>
# A basic anonymous configuration, no upload directories. If you do not
# want anonymous users, simply delete this entire <Anonymous> section.
# Uncomment lines with only one # to allow basic anonymous access #
#<Anonymous ~ftp>
# User ftp
# Group ftp
### We want clients to be able to login with "anonymous" as well as "ftp"
UserAlias anonymous ftp
### Limit the maximum number of anonymous logins
# MaxClients 10
### We want 'welcome.msg' displayed at login, and '.message' displayed
### in each newly chdired directory.
# DisplayLogin welcome.msg
# DisplayFirstChdir .message
### Limit WRITE everywhere in the anonymous chroot
# <Limit WRITE>
# DenyAll
# </Limit>
#</Anonymous>
