pessoal,
o Airaya 4958N ao carregar firmware 1.026 no telnet tem opçao de habilitar cartoes 2Ghz, onde pode ser modelo 2225N ou 2458N.
Código :AIRAYA WirelessGRID Ver 1.026. Type (Help) for Command List AIRAYA wlan0 -> admin 0968d894f5b3f61d ca4382c5350497d9 AIRAYA wlan0 -> countrycode Country Code Configuration: Product Model not initialized Country Code not initialized Making changes in this routine will delete the bridge configuration files. Make sure you have saved any configuration information before making changes. Enter y or Y to configure the Product Model: y Choose from the following list: 1 4958-32 2 4958-2 3 4958-PS 4 2225-32 5 2458-124 Enter Model ID Number: 4 Enter y or Y to configure the Country Code: y Choose from the following list: 1 US 2 HongKong 3 ETSI 4 HongKong-EMSD 5 Chile - 1 6 Saudi Arabia 7 All Bands 8 Australia 9 Malaysia 10 Singapore 11 South Africa 12 Brazil Enter Country Code ID Number: 7 Config Files Deleted. Default files will be generated on reboot! AIRAYA wlan0 -> reboot Rebooting AP... Connection to host lost.
más pelo q vi nao funciona ambos card ao mesmo tempo.
Lee
