Amigos estou tendo um grande problema aqui estou a configurar um servidor de proxy em Corel 2 Duo, com 2Gb de Ram e HD Sata2 de 150Gb, porem o proxy esta muito lento, segue abaixo o meu squid.conf se alguem tiver uma dica fico muito grato
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 # https
acl CONNECT method CONNECT
http_access deny manager
# Deny requests to unknown ports
http_access deny !Safe_ports
# Deny CONNECT to other than SSL ports
acl rede src 200.153.55.0/25
http_access allow rede
http_access allow localhost
http_access deny all
icp_access allow all
# Squid normally listens to port 3128
http_port 8080 transparent
#We recommend you to use at least the following line.
hierarchy_stoplist cgi-bin ?
cache_mem 512 MB
maximum_object_size_in_memory 32 KB
cache_dir ufs /var/spool/squid 20000 32 256
minimum_object_size 0 KB
maximum_object_size 64 KB
cache_swap_low 90
cache_swap_high 95
access_log /var/log/squid/access.log squid
pid_filename /var/run/squid.pid
ftp_user [email protected]
ftp_passive on
#We recommend you to use the following two lines.
cache deny QUERY
#Suggested default:
refresh_pattern . 0 20% 4320
# Apache to signal ETag correctly on such responses
acl apache rep_header Server ^Apache
broken_vary_encoding allow apache
ie_refresh on
#Default:
cache_effective_user squid
visible_hostname proxy.velbras.com.br
unique_hostname proxy.velbras.com.br
icon_directory /usr/share/squid/icons
dns_nameservers 189.20.243.27 201.63.34.130
append_domain .velbras.com.br
coredump_dir /var/spool/squid
Clecio
Citação
