ae pessoal mais uma nova versao, cada dia melhorando mais e mais.
What's new in 3.10:
*) added Multilink PPP to PPPoE client - just specify multiple interfaces
to enable it;
*) added ability to add dynamicly PPTP, L2TP & PPPoE client addresses
to firewall address-list, specified in ppp profile,
or via RADIUS in Mikrotik:19;
*) added address-list attribute support in user-manager;
*) added fan control for RB433;
*) console:
fixed 'interface wireless print detail', now shows the same output as
'interface wireless print basic';
fixed print to file, now writes complete contents, fixed resource leak;
show name of running scripts in '/system script job', update
'last-started' value;
could not use item names for '/interface ovpn-server' and
'/interface ovpn-client', fixed;
fixed problems with export:
some settings were not included in full export, such as
'/interface wireless nstreme');
some settings had duplicate entries with an error, such as
'/system ntp client' when ntp package was enabled;
long parameter values were incorrectly split across multiple lines;
export now quotes all values that are split across multiple lines, it
also adds line split before all newline characters, which improves
readability of exported script sources;
*) api - some properties were included multiple times in getall responses;
*) port - properly tag all inactive ports;
*) port - fixed memory leak that was triggered by addition/removal of
USB serial ports;
*) changed post-boot critical log messages - write a separate log entry
explainig the cause of an non-administrative reboot, such as watchdog
ping timeout, even if system rebooted cleanly;
*) fixed user-manager 'database rebuild' command to correct database errors;
*) fixed bug - user-manager customer password was not decoded
correctly when database backup was transferred
between Intel/RB100/RB500 and RB300/RB400/RB600/RB1000;
*) fixed bug - "/blink" command did not work on RB300/RB600/RB1000;
*) allow to configure OSPF authentication key ID;
*) allow to include bridge interface in a mesh interface;
*) ipsec - added Dead Peer Detection;
*) fixed some random crashes on RB411 & RB433;
*) fixed bug - OpenVPN could corrupt data on high load and force other end to disconnect;
*) fixed bug - DHCP server did not return DHCP options in response to
DHCPINFORM request;
Citação
