Ola Senhores(as).
Existe alguma regra específica para que possa ser feito o cache do youtube, seja via mod-rewrite no squid ou no mikrotik (que acho difícil, mas não impossivel).
Obrigado galera.
Ola Senhores(as).
Obrigado galera.
Apesar de tentar que alguem me desse uma luz, me surpreendi!(ambuguidade).
Achei um script que esta rodando em meu server e fez o cache do youtube senhores.
Pena que ele usa o squid fora do MK e deve ser a versão 2.6 ou acima e ter o perl para rodar o script de redirecionamento vi HIT, seque o script.
> http_port 3128
> append_domain .esri.com
> acl apache rep_header Server ^Apache
> broken_vary_encoding allow apache
> maximum_object_size 4194240 KB
> maximum_object_size_in_memory 1024 KB
> access_log /usr/local/squid/var/logs/access.log squid
> # Some refresh patterns including YouTube -- although YouTube probably
> needs to
> # be adjusted.
> refresh_pattern ^ftp: 1440 20% 10080
> refresh_pattern ^gopher: 1440 0% 1440
> refresh_pattern -i \.flv$ 10080 90% 999999 ignore-no-cache
> override-expire ignore-private
> refresh_pattern ^http://sjl-v[0-9]+\.sjl\.youtube\.com 10080 90% 999999
> ignore-no-cache override-expire ignore-private
> refresh_pattern get_video\?video_id 10080 90% 999999 ignore-no-cache
> refresh_pattern youtube\.com/get_video\? 10080 90% 999999 ignore-no-cache
> refresh_pattern . 0 20% 4320
> acl all src 0.0.0.0/0.0.0.0
> acl esri src 10.0.0.0/255.0.0.0
> acl manager proto cache_object
> acl localhost src 127.0.0.1/255.255.255.255
> acl to_localhost dst 127.0.0.0/8
> acl SSL_ports port 443
> acl Safe_ports port 80 # http
> acl Safe_ports port 21 # ftp
> acl Safe_ports port 443 # https
> acl Safe_ports port 70 # gopher
> acl Safe_ports port 210 # wais
> acl Safe_ports port 1025-65535 # unregistered ports
> acl Safe_ports port 280 # http-mgmt
> acl Safe_ports port 488 # gss-http
> acl Safe_ports port 591 # filemaker
> acl Safe_ports port 777 # multiling http
> acl CONNECT method CONNECT
> # Some Youtube ACL's
> acl youtube dstdomain .youtube.com .googlevideo.com .video.google.com
> .video.google.com.au
> acl youtubeip dst 74.125.15.0/24
> acl youtubeip dst 64.15.0.0/16
> cache allow youtube
> cache allow youtubeip
> cache allow esri
> # These are from Features/StoreUrlRewrite - Squid Web Proxy Wiki
> acl store_rewrite_list dstdomain mt.google.com mt0.google.com
> mt1.google.com mt2.google.com
> acl store_rewrite_list dstdomain mt3.google.com
> acl store_rewrite_list dstdomain kh.google.com kh0.google.com
> kh1.google.com kh2.google.com
> acl store_rewrite_list dstdomain kh3.google.com
> acl store_rewrite_list dstdomain kh.google.com.au kh0.google.com.au
> kh1.google.com.au
> acl store_rewrite_list dstdomain kh2.google.com.au kh3.google.com.au
> # This needs to be narrowed down quite a bit!
> acl store_rewrite_list dstdomain .youtube.com
> storeurl_access allow store_rewrite_list
> storeurl_access deny all
> storeurl_rewrite_program /usr/local/bin/store_url_rewrite
> http_access allow manager localhost
> http_access deny manager
> http_access deny !Safe_ports
> http_access deny CONNECT !SSL_ports
> http_access allow localhost
> http_access allow esri
> http_access deny all
> http_reply_access allow all
> icp_access allow all
> coredump_dir /usr/local/squid/var/cache
> # YouTube options.
> quick_abort_min -1 KB
> # This will block other streaming media. Maybe we don't want this, but
> using
> # it for now.
> hierarchy_stoplist cgi-bin ?
> acl QUERY urlpath_regex cgi-bin \?
> cache deny QUERY
> And here is the store_url_rewrite script. I added some logging:
> #!/usr/bin/perl
> use IO::File;
> use IO::Socket::INET;
> use IO::Pipe;
> $| = 1;
> $fh = new IO::File("/tmp/debug.log", "a");
> $fh->print("Hello!\n");
> $fh->flush();
> while (<>) {
> chomp;
> #print LOG "Orig URL: " . $_ . "\n";
> $fh->print("Orig URL: " . $_ . "\n");
> if (m/kh(.*?)\.google\.com(.*?)\/(.*?) /) {
> print "http://keyhole-srv.google.com"; . $2 .
> ".SQUIDINTERNAL/" . $3 . "\n";
> # print STDERR "KEYHOLE\n";
> } elsif (m/mt(.*?)\.google\.com(.*?)\/(.*?) /) {
> print "http://map-srv.google.com"; . $2 . ".SQUIDINTERNAL/"
> . $3 . "\n";
> # print STDERR "MAPSRV\n";
> } elsif
> (m/^http:\/\/([A-Za-z]*?)-(.*?)\.(.*)\.youtube\.com\/get_video\?video_id=([^&]+).*
> "http://video-srv.youtube.com.SQUIDINTERNAL/get_video?video_id="; . $4 . "\n";
> $fh->print("http://video-srv.youtube.com.SQUIDINTERNAL/get_video?video_id="; .
> $4 . "\n");
> $fh->flush();
> } elsif
> (m/^http:\/\/([A-Za-z]*?)-(.*?)\.(.*)\.youtube\.com\/get_video\?video_id=(.*)
> http://lax-v290.lax.youtube.com/get_...id=jqx1ZmzX0k0
> } else {
> print $_ . "\n";
