ola a todos!
to tentando instalar o proftpd + mysql e não to tendo muito sucesso nessa, o que ocorre é que quando vou iniciar o proftpd simplimente ele não inicia e nem me reporta log.
a versão que estou usando:
proftpd-1.3.1-1.el5.rf
proftpd-mysql-1.3.1-1.el5.rf
distro = centos 5.1
proftpd.conf:
ServerName "Teste FTP server"
ServerIdent on "FTP Server ready."
ServerAdmin [email protected]
ServerType standalone
#ServerType inetd
DefaultServer on
AccessGrantMsg "User %u logged in."
#DisplayConnect /etc/ftpissue
#DisplayLogin /etc/ftpmotd
#DisplayGoAway /etc/ftpgoaway
DeferWelcome off
# Use this to excude users from the chroot
#DefaultRoot ~ !adm
DefaultRoot ~
# Use pam to authenticate (default) and be authoritative
#AuthPAMConfig proftpd
#AuthOrder mod_auth_pam.c* mod_auth_unix.c
# Do not perform ident nor DNS lookups (hangs when the port is filtered)
IdentLookups off
UseReverseDNS off
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# Default to show dot files in directory listings
ListOptions "-a"
# See Configuration.html for these (here are the default values)
#MultilineRFC2228 off
#RootLogin off
#LoginPasswordPrompt on
#MaxLoginAttempts 3
#MaxClientsPerHost none
#AllowForeignAddress off # For FXP
# Allow to resume not only the downloads but the uploads too
AllowRetrieveRestart on
AllowStoreRestart on
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 20
# Set the user and group that the server normally runs at.
User nobody
Group nobody
# Disable sendfile by default since it breaks displaying the download speeds in
# ftptop and ftpwho
UseSendfile no
# This is where we want to put the pid file
ScoreboardFile /var/run/proftpd.score
# Normally, we want users to do a few things.
<Global>
AllowOverwrite yes
<Limit ALL SITE_CHMOD>
AllowAll
</Limit>
</Global>
# Define the log formats
LogFormat default "%h %l %u %t \"%r\" %s %b"
LogFormat auth "%v [%P] %h %t \"%r\" %s"
TimeoutLogin 60
TimeoutNoTransfer 120
TimeoutIdle 180
TransferRate RETR 8:10
TransferLog /var/log/proftpd/xferlog
SystemLog /var/log/proftpd/proftpd.log
# TLS
# Explained at ProFTPD module mod_tls
#TLSEngine on
#TLSRequired on
#TLSRSACertificateFile /etc/pki/tls/certs/proftpd.pem
#TLSRSACertificateKeyFile /etc/pki/tls/certs/proftpd.pem
#TLSCipherSuite ALL:!ADH:!DES
#TLSOptions NoCertRequest
#TLSVerifyClient off
##TLSRenegotiate ctrl 3600 data 512000 required off timeout 300
#TLSLog /var/log/proftpd/tls.log
# SQL authentication Dynamic Shared Object (DSO) loading
# See README.DSO and howto/DSO.html for more details.
#<IfModule mod_dso.c>
# LoadModule mod_sql.c
# LoadModule mod_sql_mysql.c
# LoadModule mod_sql_postgres.c
#</IfModule>
# A basic anonymous configuration, with an upload directory.
#<Anonymous ~ftp>
# User ftp
# Group ftp
# AccessGrantMsg "Anonymous login ok, restrictions apply."
# # We want clients to be able to login with "anonymous" as well as "ftp"
# UserAlias anonymous ftp
# # Limit the maximum number of anonymous logins
# MaxClients 10 "Sorry, max %m users -- try again later"
# # Put the user into /pub right after login
# #DefaultChdir /pub
# # We want 'welcome.msg' displayed at login, '.message' displayed in
# # each newly chdired directory and tell users to read README* files.
# DisplayLogin /welcome.msg
# DisplayFirstChdir .message
# DisplayReadme README*
# # Some more cosmetic and not vital stuff
# DirFakeUser on ftp
# DirFakeGroup on ftp
# # Limit WRITE everywhere in the anonymous chroot
# <Limit WRITE SITE_CHMOD>
# DenyAll
# </Limit>
# # An upload directory that allows storing files but not retrieving
# # or creating directories.
# <Directory uploads/*>
# AllowOverwrite no
# <Limit READ>
# DenyAll
# </Limit>
# <Limit STOR>
# AllowAll
# </Limit>
# </Directory>
# # Don't write anonymous accesses to the system wtmp file (good idea!)
# WtmpLog off
# # Logging for the anonymous transfers
# ExtendedLog /var/log/proftpd/access.log WRITE,READ default
# ExtendedLog /var/log/proftpd/auth.log AUTH auth
#</Anonymous>
# The passwords in MySQL are encrypted using CRYPT
SQLAuthTypes Plaintext Crypt
SQLAuthenticate users* groups*
# used to connect to the database
# databasename@host database_user user_password
SQLConnectInfo ftp@localhost proftpd 123456
# Here we tell ProFTPd the names of the database columns in the "usertable"
# we want it to interact with. Match the names with those in the db
SQLUserInfo ftpuser userid passwd uid gid homedir shell
# Here we tell ProFTPd the names of the database columns in the "grouptable"
# we want it to interact with. Again the names match with those in the db
SQLGroupInfo ftpgroup groupname gid members
# set min UID and GID - otherwise these are 999 each
SQLMinID 500
# create a user's home directory on demand if it doesn't exist
SQLHomedirOnDemand on
# Update count every time user logs in
SQLLog PASS updatecount
SQLNamedQuery updatecount UPDATE "count=count+1, accessed=now() WHERE userid='%u'" ftpuser
# Update modified everytime user uploads or deletes a file
SQLLog STOR,DELE modified
SQLNamedQuery modified UPDATE "modified=now() WHERE userid='%u'" ftpuser
# User quotas
QuotaEngine on
QuotaDirectoryTally on
QuotaDisplayUnits Mb
QuotaShowQuotas on
SQLNamedQuery get-quota-limit SELECT "name, quota_type, per_session, limit_type, bytes_in_avail, bytes_out_avail, bytes_xfer_avail, files_in_avail, files_out_avail, files_xfer_avail FROM ftpquotalimits WHERE name = '%{0}' AND quota_type = '%{1}'"
SQLNamedQuery get-quota-tally SELECT "name, quota_type, bytes_in_used, bytes_out_used, bytes_xfer_used, files_in_used, files_out_used, files_xfer_used FROM ftpquotatallies WHERE name = '%{0}' AND quota_type = '%{1}'"
SQLNamedQuery update-quota-tally UPDATE "bytes_in_used = bytes_in_used + %{0}, bytes_out_used = bytes_out_used + %{1}, bytes_xfer_used = bytes_xfer_used + %{2}, files_in_used = files_in_used + %{3}, files_out_used = files_out_used + %{4}, files_xfer_used = files_xfer_used + %{5} WHERE name = '%{6}' AND quota_type = '%{7}'" ftpquotatallies
SQLNamedQuery insert-quota-tally INSERT "%{0}, %{1}, %{2}, %{3}, %{4}, %{5}, %{6}, %{7}" ftpquotatallies
QuotaLimitTable sql:/get-quota-limit
QuotaTallyTable sql:/get-quota-tally/update-quota-tally/insert-quota-tally
RootLogin off
RequireValidShell off
SQLNamedQuery gettally SELECT "ROUND((bytes_in_used/1048576),2) FROM ftpquotatallies WHERE name='%u'"
SQLNamedQuery getlimit SELECT "ROUND((bytes_in_avail/1048576),2) FROM ftpquotalimits WHERE name='%u'"
SQLNamedQuery getfree SELECT "ROUND(((ftpquotalimits.bytes_in_avail-ftpquotatallies.bytes_in_used)/1048576),2) FROM ftpquotalimits,ftpquotatallies WHERE ftpquotalimits.name = '%u' AND ftpquotatallies.name = '%u'"
SQLShowInfo LIST "226" "Used %{gettally}MB from %{getlimit}MB. You have %{getfree}MB available space."
o que me parece, é que o proftpd não ta carregando o modulo mod_sql, mod_sql_mysql
proftpd -l
Compiled-in modules:
mod_core.c
mod_xfer.c
mod_auth_unix.c
mod_auth_file.c
mod_auth.c
mod_ls.c
mod_log.c
mod_site.c
mod_delay.c
mod_dso.c
mod_readme.c
mod_auth_pam.c
mod_tls.c
mod_cap.c
mod_ctrls.c
alguem tem alguma ideia de como proceder nesse caso.?
