alguem ja usou esse balanceamento?? axei essas regras para aplicar que fiquei até com medo!!!! poi tenho 1 link dedicado e 1 adsl e queria implantar de madruga, para nao ter problema, q vcx axam , tem 2 modos que axei:::
BALANCEAMENTO ENTRE 2 LINKS
/ ip firewall mangle
add chain=prerouting in-interface= Local connection-state=new nth=1,1,0 action=mark-connection new-connection-mark=odd passthrough=yes comment="Balanceamento de carga" disabled=no
add chain=prerouting in-interface= Local connection-mark=odd action=mark-routing new-routing-mark=odd passthrough=no comment="" disabled=no
add chain=prerouting in-interface= Local connection-state=new nth=1,1,1 action=mark-connection new-connection-mark=even passthrough=yes comment="" disabled=no
add chain=prerouting in-interface= Local connection-mark=even action=mark-routing new-routing-mark=even passthrough=no comment="" disabled=no
/ ip firewall nat
add chain=srcnat connection-mark=odd action=src-nat to-addresses=192.168.15.199 to-ports=0-65535 comment="Balanceamento de carga" disabled=no
add chain=srcnat connection-mark=even action=src-nat to-addresses=192.168.241.73 to-ports=0-65535 comment="" disabled=no
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.15.254 scope=255 target-scope=10 routing-mark=odd comment="Gateway SttarNet" disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.251.254 scope=255 target-scope=10 routing-mark=even comment="Gateway INova" disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.15.254 scope=255 target-scope=10 comment="principal" disabled=yes
MODDOOOOO 2 QUE AXEI
BALANCEAMNETO DE PORTAS
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.15.254 scope=255 target-scope=10 \
routing-mark=link1 comment="Pacotes marcados redirecionados para o link1" \
disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.251.254 scope=255 target-scope=10 \
routing-mark=link2 comment="Pacotes marcados redirecionados para o link2" \
disabled=no
add chain=prerouting protocol=tcp dst-port=80 action=mark-routing new-routing-mark=link2 passthrough=yes \
comment="Portas redirecionada para o link2" disabled=no
add chain=prerouting protocol=tcp dst-port=443 action=mark-routing new-routing-mark=link2 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=1863 action=mark-routing new-routing-mark=link2 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=6891 action=mark-routing new-routing-mark=link2 passthrough=yes \
add chain=prerouting routing-mark=link2 action=mark-packet new-packet-mark=link2 passthrough=yes \
comment="Pacotes marcados do Link2" disabled=no
add chain=prerouting routing-mark=link2 action=mark-packet new-packet-mark=link1 passthrough=yes \
comment="Pacotes marcados do Link1" disabled=no
add chain=prerouting protocol=tcp dst-port=21 action=mark-routing new-routing-mark=link1 passthrough=yes \
comment="Portas redirecionada para o link1" disabled=no
add chain=prerouting protocol=tcp dst-port=22 action=mark-routing new-routing-mark=link1 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=23 action=mark-routing new-routing-mark=link1 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=25 action=mark-routing new-routing-mark=link1 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=53 action=mark-routing new-routing-mark=link1 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=110 action=mark-routing new-routing-mark=link1 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=1080 action=mark-routing new-routing-mark=link1 passthrough=yes \
add chain=prerouting protocol=tcp dst-port=443 action=mark-routing new-routing-mark=link1 passthrough=yes \
add chain=prerouting protocol=tcp p2p=all-p2p action=mark-routing new-routing-mark=link1 passthrough=yes \
comment="p2p 1 redirecionado link1" disabled=no
ESSE segundo axei axo mais legal, pois como tenho 1 link dedicado seria massa garantir algumas coisa para meu link, o que vcx axam , sao simples assim mesmo?? tem algo a mais ou a menos?
Citação
