Amigos,
Configurei um Samba + Ldap como PDC. Criei o usuário root no Ldap e logado como administrador local na minha máquina Win XP, tentei adicionar no domínio e recebo a mensagem: "Não foi possível localizar o nome de usuário".
Verifiquei no grupo "Computers" do ldap e foi criada a conta para a máquina. Que usuário é esse que não foi encontrado?
Segue o meu smb.conf
[global]
kernel oplocks = yes
workgroup = SULSOFT
server string = Servidor Hannabarbera
announce as = NT Server
nt acl support = yes
wins support = yes
# This will prevent nmbd to search for NetBIOS names through DNS.
dns proxy = no
# support for the Windows privilege model
enable privileges = yes
# Adicionar maquinas no Ldap
add machine script = /usr/sbin/smbldap-useradd -t 5 -w "%u"
# What naming service and in what order should we use to resolve host names
name resolve order = lmhosts host wins bcast
#### Networking ####
# The specific set of interfaces / networks to bind to
;interfaces = eth0
;bind interfaces only = true
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
log file = /var/log/samba/%m.log
log level = 2
# Put a capping on the size of the log files (in Kb).
max log size = 5000
# We want Samba to log a minimum amount of information to syslog.
syslog only = no
syslog = 0
####### Authentication #######
security = user
encrypt passwords = true
# Passwords no Ldap
passdb backend = ldapsam:ldap://127.0.0.1
ldap suffix = dc=sulsoft,dc=com,dc=br
ldap machine suffix = ou=computers
ldap user suffix = ou=users
ldap group suffix = ou=groups
ldap admin dn = cn=admin,dc=sulsoft,dc=com,dc=br
ldap delete dn = no
ldap password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
passwd program = /usr/sbin/smbldap-passwd -u %u
passwd chat = "Alterar senha para *\nNova senha*" %n\n "*Repita a nova senha*" %n\n"
########## Domains ###########
# CONTROLADOR DE DOMINIO
local master = yes
domain master = yes
os level = 150
preferred master = yes
logon script = %U.bat
domain logons = yes
logon path = \\%L\Profiles\%U
logon drive = H:
########## Printing ##########
# If you want to automatically load your printer list rather
# than setting them up individually then you'll need this
load printers = yes
# Impressao gerenciada pelo Cups
printing = cups
printcap name = cups
cups options = raw
# When using [print$], root is implicitly a 'printer admin', but you can
# also give this right to other users to add drivers and set printer
# properties
; printer admin = @ntadmin
############ Misc ############
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
# The following parameter is useful only if you have the linpopup package
; message command = /bin/sh -c '/usr/bin/linpopup "%f" "%m" %s; rm %s' &
#======================= Share Definitions =======================
[homes]
comment = Home Directories - SulSoft
path = /home/sulsoft/%U
browseable = no
writable = yes
veto files = /*.mp3/*.avi/*.mpeg/*.mpg/*.asf/*.divx/*.wma/*.pif/*.scr/*.wmv/
[Central_de_arquivos]
comment = Central de arquivos
path = /home/Dados/Central_de_arquivos
browseable = yes
writable = yes
valid users = @users
public = no
[Publico]
comment = Pasta publica
path = /home/Dados/Publico
browseable = yes
writable = yes
public = yes
[Storage]
comment = Repositorio de arquivos
path = /home/Dados/Storage
browseable = yes
writable = yes
public = no
valid users = alexandro
[backups]
comment = Backups de arquivos
path = /home/Dados/backups
browseable = no
writable = yes
public = no
[netlogon]
comment = Network Logon Service
path = /home/Dados/netlogon
browseable = no
public = yes
writable = no
share modes = no
#[profiles]
# comment = Users profiles
# path = /home/samba/profiles
# public = no
# guest ok = no
# browseable = no
# writable = yes
# veto files = /*.mp3/*.avi/*.mpeg/*.mpg/*.asf/*.divx/*.wma/*.pif/*.scr/
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
public = yes
guest ok = yes
writable = no
[print$]
path = /var/lib/samba/printers
browseable = no
read only = yes
guest ok = yes
read only = yes
write list = @admin, root
