Pessoal instalei o vsftpd ok via apt-get, ae fiz a config tudo certo, porem depois de logar ele não aceita comando da esta mensagem em baixo, mais se for do localhost os comandos rodam na boa
Logando externamente
220 Welcome to Rip Curl Brazil FTP service.
Name (200.228.110.4:root): repiozzi
331 Please specify the password.
Password:
230 Login successful.
Remote system type is UNIX.
Using binary mode to transfer files.
ftp> ls
200 PORT command successful. Consider using PASV.
425 Failed to establish connection.
Logamdo internamente Ok
bells:/etc/samba# ftp
ftp> open
(to) localhost
Connected to localhost.
Name (localhost:root): repiozzi
Password:
ftp> ls
150 Here comes the directory listing.
-rwxrwxrwx 1 0 0 0 Oct 13 13:28 teste.txt
226 Directory send OK.
ftp>
Citação
