- Som Crystal CS4232
Som Crystal CS4232
Pessoal, to com um RH 9 e uma placa de som isa cs4232
quando tento configura-la pelo sndconf vai blz e no fim me dah erro pra adcionar o modulo
no /var/log/messages aparace isso:
Nov 5 14:05:31 max kernel: ad1848/cs4248 codec driver Copyright (C) by Hannu Savolainen 1993-1996
Nov 5 14:05:31 max kernel: ad1848: No ISAPnP cards found, trying standard ones...
Nov 5 14:05:31 max kernel: cs4232: set synthio and synthirq to use the wavefront facilities.
Nov 5 14:05:59 max kernel: ad1848/cs4248 codec driver Copyright (C) by Hannu Savolainen 1993-1996
Nov 5 14:05:59 max kernel: ad1848: No ISAPnP cards found, trying standard ones...
Nov 5 14:05:59 max kernel: cs4232: set synthio and synthirq to use the wavefront facilities.
Nov 5 14:27:17 max kernel: cdrom: This disc doesn´t have any tracks I recognize!
Nov 5 14:27:48 max modprobe: modprobe: Can´t locate module sound-slot-0
Nov 5 14:27:48 max modprobe: modprobe: Can´t locate module sound-service-0-3
naum faço a minima ideia d como arrumar, alguem tem alguma ideia??
[]´s
Som Crystal CS4232
Bom amigo, tente com os drivers da alsa, eles já me quebraram muito galho, segue instrucoes:
http://www.alsa-project.org/alsa-doc...&module=cs4232
