include "/etc/rndc.key";
controls {
inet 127.0.0.1 allow { localhost; } keys { "rndc-key"; };
options
/* make named use port 53 for the source of all queries, to allow
* firewalls to block all ports except 53:
query-source port 53;
// Put files that named is allowed to write in the data/ directory:
directory "/var/named"; // the default
dump-file "data/cache_dump.db";
statistics-file "data/named_stats.txt";
memstatistics-file "data/named_mem_stats.txt";
logging
/* If you want to enable debugging, eg. using the 'rndc trace' command,
* named will try to write the 'named.run' file in the $directory (/var/named).
* By default, SELinux policy does not allow named to modify the /var/named directory,
* so put the default debug log file in data/ :
channel default_debug {
file "data/named.run";
severity dynamic;
// All BIND 9 zones are in a "view", which allow different zones to be served
// to different types of client addresses, and for options to be set for groups
// of zones.
// By default, if named.conf contains no "view" clauses, all zones are in the
// "default" view, which matches all clients.
// If named.conf contains any "view" clause, then all zones MUST be in a view;
// so it is recommended to start off using views to avoid having to restructure
// your configuration files in the future.
view "localhost_resolver"
/* This view sets up named to be a localhost resolver ( caching only nameserver ).
* If all you want is a caching-only nameserver, then you need only define this view:
match-clients { localhost; };
match-destinations { localhost; };
recursion yes;
zone "." IN {
type hint;
file "/var/named/named.ca";
[B] zone "rn1.com.br" IN {
type master;
file "db/rn1.com.br";
zone "xxx.xxx.201.in-addr.arpa" IN {
type master;
file "db/rn1.rev";
};[/B]
/* these are zones that contain definitions for all the localhost
* names and addresses, as recommended in RFC1912 - these names should
* ONLY be served to localhost clients:
include "/var/named/named.rfc1912.zones";
view "internal"
/* This view will contain zones you want to serve only to "internal" clients
that connect via your directly attached LAN interfaces - "localnets" .
match-clients { localnets; };
match-destinations { localnets; };
recursion yes;
zone "." IN {
type hint;
// include "/var/named/named.rfc1912.zones";
// you should not serve your rfc1912 names to non-localhost clients.
// These are your "authoritative" internal zones, and would probably
// also be included in the "localhost_resolver" view above :
view "external"
/* This view will contain zones you want to serve only to "external" clients
* that have addresses that are not on your directly attached LAN interface subnets:
recursion no;
// you'd probably want to deny recursion to external clients, so you don't
// end up providing free DNS service to all takers
// all views must contain the root hints zone:
zone "." IN {
type hint;
// These are your "authoritative" external zones, and would probably
// contain entries for just your web and mail servers:
// BEGIN external zone entries
