Ja segui um tororial no forum mas nao funcionou se alguem poder me ajudar aonde estou errando ?
Coloquei o nome nas interfaces
RB(A) SSID: CANAL
wlan1 - Chamei de TX TX_LINK 5825
wlan2 - Chamei de RX RX_LINK 5320
RB(b) SSID: CANAL
config do nstreme dual na RB (b)
Flags: X - disabled, R - running
0 R name="nstreme1" mtu=1500 mac-address=00:02:6F:4D:89:F6 arp=enabled
disable-running-check=no tx-radio=TX rx-radio=RX
remote-mac=00:02:6F:4D:8C:05 tx-band=5ghz tx-frequency=5320
rx-band=5ghz rx-frequency=5825 rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps, 36Mbps,48Mbps,54Mbps
framer-policy=best-fit framer-limit=3200
config do nstreme dual na RB (a)
0 R name="nstreme1" mtu=1500 mac-address=00:02:6F:4D:8C:05 arp=enabled
remote-mac=00:02:6F:4D:89:F6 tx-band=5ghz tx-frequency=5320
rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
Os 4 Cartoes sao Engenius EMNP8602 e nao esta comunicando ja testei a RB como wds funciona blz mas zero a config tento o nstreme dual nao funciona se alguem poder me ajudar
