Saiu o MK 4.0 Beta e 3.17 Stable.
Link:http://www.mikrotik.com/download.html
What's new in 3.17:
*) added support for Intel 10Gb PCI Express driver;
*) made Huawei E220 USB modem work again;
*) added support for Novatel Wireless Ovation MC950D HSUPA;
*) fixed PCQ fairness when pcq-total-limit is reached;
*) fixed fetch tool to work when dst-path is not specified (broken in 3.16);
*) fetch tool - added keep-result command line argument;
*) allow to specify routing-table for ping, trace-route, and telnet;
*) fixed an IPsec bug;
*) fixed /ip firewall address-list;
*) added propagate-ttl option for MPLS;
*) fix very long wireless scan-list issues;
*) fixed problem - sometimes PCQ could stop data pass-through if pcq-rate was set;
*) fixed problem - L2TP could stop working when one of clients stopped responding
at wrong time;
*) fixed problem - reduced size of supout.rif files;
*) graphing - support for 10 Gbit interfaces;
*) routing-test - added support for multi-instance OSPF;
*) user manager - fixed bug for PayPal payments with long parameter list;
*) user manager - database load command supports external storage
for temporary files;
*) user manager - added support for all UTC time-zone offsets,
including +5:30, +5:45, etc.;
*) allow queues to have all traffic, not only ip (for example vpn)
*) improved ipv6 sniffing
*) improve torch and sniffer behavior under high load
*) improved queue statistics
Known issues:
*) on some SMP x86 boxes clocks are not right, time runs very fast on them, as a result
queues & wireless-test nstreme does not work;
Citação
