Ola, estive tentando instalar meu modem hsp56 da pctel e ocorreu um erro durante a instalação abaixo esta descrita a saida do terminal.
[root@localhost pctel-0.9.6]# ./configure --with-hal=cm8738 --with-kernel-includes=/usr/src/linux/include
make
configure: WARNING: you should use --build, --host, --target
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets ${MAKE}... yes
checking build driver for... HAL_CM8738
checking for make-gcc... no
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of gcc... none
checking whether make sets ${MAKE}... (cached) yes
checking whether ln -s works... yes
checking for gawk... (cached) gawk
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking /usr/src/linux/include/linux/modversions.h usability... no
checking /usr/src/linux/include/linux/modversions.h presence... no
checking for /usr/src/linux/include/linux/modversions.h... no
configure: error: modversions.h is missing - you should configure your kernel first!
Se alguem puder me ajudar com isso agradeço.
Ps: A distro que estou utilizando é a Red Hat 9. Por favor alguem me ajude!!!!!!
