- Hylafax
Hylafax
Saudações amigos estou instalando um servidor de fax (Hylafax) estou com diversos problemas, alguém ja configurou o hylafax..alguém pode me ajudar???
Hylafax
qual eh o grilo...
Já instalei Hylafax, deu uma dorzinha de cabeça para aprender a mexer com ele mas rolou de boa...
Hylafax
Não estou conseguindo fazer ele mandar o email com anexo, acho que meu arquivo faxrecvd está com problemas..............Consigo enviar e receber o fax....
Obrigado
Hylafax
#! /bin/sh
# $Id: faxrcvd.sh.in,v 1.9 2003/02/09 02:39:33 darren Exp $
# HylaFAX Facsimile Software
# Copyright (c) 1990-1996 Sam Leffler
# Copyright (c) 1991-1996 Silicon Graphics, Inc.
# HylaFAX is a trademark of Silicon Graphics
# Permission to use, copy, modify, distribute, and sell this software and
# its documentation for any purpose is hereby granted without fee, provided
# that (i) the above copyright notices and this permission notice appear in
# all copies of the software and related documentation, and (ii) the names of
# Sam Leffler and Silicon Graphics may not be used in any advertising or
# publicity relating to the software without the specific, prior written
# permission of Sam Leffler and Silicon Graphics.
# THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
# EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
# WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
# IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
# ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
# OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
# WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
# LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
# OF THIS SOFTWARE.
# faxrcvd file devID commID error-msg
if [ $# -lt 4 ]; then
echo "Usage: $0 file devID commID error-msg CIDNumber CIDName "
exit 1
fi
test -f etc/setup.cache || {
SPOOL=`pwd`
cat<<EOF
FATAL ERROR: $SPOOL/etc/setup.cache is missing!
The file $SPOOL/etc/setup.cache is not present. This
probably means the machine has not been setup using the faxsetup(8C)
command. Read the documentation on setting up HylaFAX before you
startup a server system.
EOF
exit 1
. etc/setup.cache
INFO=$SBIN/faxinfo
FAX2PS=$TIFFBIN/fax2ps
MIMENCODE=mimencode
ENCODING=base64
TIFF2PS=tiff2ps
PS2PDF=ps2pdf
TOADDR=FaxMaster
TIFFINFO=tiffinfo
NOTIFY_FAXMASTER=always
FAX2PDF=fax2pdf
tiffile=/var/spool/hylafax/recvq/
pdffile=/var/spool/hylafax/recvq/
# Permit various types of attachment types: ps, tif, pdf
# Note that non-ASCII filetypes require metamail.
# pdf requires tiff2ps and ps2pdf
FILETYPE=pdf
# There is no good portable way to find out the fully qualified
# domain name (FQDN) of the host or the TCP port for the hylafax
# service so we fudge here. Folks may want to tailor this to
# their needs; e.g. add a domain or use localhost so the loopback
# interface is used.
HOSTNAME=`hostname` # XXX no good way to find FQDN
PORT=4559 # XXX no good way to lookup service
FILE="$1"
DEVICE="$2"
COMMID="$3"
MSG="$4"
CIDNUMBER="$5"
CIDNAME="$6"
FILE2=`echo $FILE |cut -c7-18`
FILE3=`echo $FILE |cut -c7-14`
FILENAME=`echo $FILE | $SED -e ´s/\.tiff//´ -e ´s/recvq\///´`
if [ -f $FILE2.pdf ]; then
# Check the sender´s TSI and setup to dispatch
# facsimile received from well-known senders.
SUBADDR="`$INFO $FILE2.pdf | $AWK -F: ´/SubAddr/ { print $2 }´ 2>/dev/null`"
SENDER="`$INFO $FILE.pdf | $AWK -F: ´/Sender/ { print $2 }´ 2>/dev/null`"
SENDTO=
if [ -f etc/FaxDispatch ]; then
. etc/FaxDispatch # NB: FaxDispatch sets SENDTO
fi
# Don´t send FaxMaster duplicates, and FaxMaster may not even
# want a message at all, depending on NOTIFY_FAXMASTER.
case $NOTIFY_FAXMASTER$MSG in
never*) NOTIFY_FAXMASTER=no;;
errors) NOTIFY_FAXMASTER=no;;
*) NOTIFY_FAXMASTER=yes;;
esac
if [ "$TOADDR" != "$SENDTO" -a "$NOTIFY_FAXMASTER" != "no" ]; then
(echo "To: $TOADDR"
echo "From: The HylaFAX Receive Agent <fax>"
echo "Subject: Facsimile received from $SENDER";
echo ""
echo "$FILE2.pdf (ftp://$HOSTNAME:$PORT/$FILE2.pdf):"; $INFO -n $FILE2.pdf
echo "ReceivedOn: $DEVICE"
if [ "$MSG" ]; then
echo ""
echo "The full document was not received because:"
echo ""
echo " $MSG"
echo ""
echo " ---- Transcript of session follows ----"
echo ""
if [ -f log/c$COMMID ]; then
$SED -e ´/-- data/d´ \
-e ´/start.*timer/d´ -e ´/stop.*timer/d´ \
log/c$COMMID
elif [ -n "$COMMID" ]; then
echo " No transcript available (CommID c$COMMID)."
else
echo " No transcript available."
fi
else
echo " CommID: c$COMMID (ftp://$HOSTNAME:$PORT/log/c$COMMID)"
fi
if [ "$CIDNUMBER" ]; then
echo " CIDNumber: $CIDNUMBER"
fi
if [ "$CIDNAME" ]; then
echo " CIDName: $CIDNAME"
fi
if [ -n "$SENDTO" ]; then
echo ""
echo "The facsimile was automatically dispatched to: $SENDTO."
fi
) | 2>&1 $SENDMAIL -ffax -oi $TOADDR
fi
(MIMEBOUNDARY="NextPart$$"
echo "Mime-Version: 1.0"
echo "Content-Type: Multipart/Mixed; Boundary=\"$MIMEBOUNDARY\""
echo "Content-Transfer-Encoding: 7bit"
echo "To: $SENDTO"
echo ""
echo "--$MIMEBOUNDARY"
echo "Content-Type: text/plain; charset=us-ascii"
echo ""
echo "$FILE (ftp://$HOSTNAME:$PORT/$FILE):"; $INFO -n $FILE
if [ "$MSG" ]; then
echo ""
echo ""
echo " $MSG"
echo ""
echo ""
log/c$COMMID
else
fi
else
fi
fi
fi
echo ""
if [ "$FILETYPE" = "tif" ]; then
echo "Content-Type: image/tiff; name=\"$FILENAME.tif\""
echo "Content-Description: FAX document"
echo "Content-Transfer-Encoding: $ENCODING"
echo "Content-Disposition: attachment; filename=\"$FILENAME.tif\""
echo ""
$MIMENCODE $FILE 2>/dev/null
elif [ "$FILETYPE" = "pdf" ]; then
echo "Content-Type: application/pdf; name=\"c$COMMID.pdf\""
echo "Content-Disposition: attachment; filename=\"c$COMMID.pdf\""
echo ""
GW=`$TIFFINFO $FILE | $GREP "Image Width" | \
$SED ´s/.*Image Width: \([0-9]*\).*/\1/g´ | sort -n | $SED -n ´$p´`
GL=`$TIFFINFO $FILE | $GREP "Image Length" | \
$SED ´s/.*Image Length: \([0-9]*\).*/\1/g´ | sort -n | $SED -n ´$p´`
RW=`$TIFFINFO $FILE | $GREP "Resolution" | \
$SED ´s/.*Resolution: \([0-9]*\).*/\1/g´ | sort -n | $SED -n ´$p´
$SED ´s/.*Resolution: \([0-9]*\).*/\1/g´ | sort -n | $SED -n ´$p´`
RL=`$TIFFINFO $FILE | $GREP "Resolution" | \
$SED ´s/.*Resolution: [0-9]*, \([0-9]*\).*/\1/g´ | sort -n | $SED -n ´$p´`
$TIFF2PS -a -O $FILE.ps $FILE 2>/dev/null # fax2ps looks bad
$PS2PDF -g$GW\x$GL -r$RW\x$RL $FILE.ps $FILE.pdf 2>/dev/null
$MIMENCODE $FILE.pdf 2>/dev/null
$RM -f $FILE.ps $FILE.pdf 2>/dev/null
else # default as Postscript
echo "Content-Type: application/postscript; name=\"$FILENAME.ps\""
echo "Content-Disposition: attachment; filename=\"$FILENAME.ps\""
echo ""
$FAX2PS $FILE 2>/dev/null
fi
echo ""
echo "--$MIMEBOUNDARY--"
) | 2>&1 $SENDMAIL -ffax -oi $SENDTO
fi
else
# Generate notification mail for a failed attempt.
(echo "To: $TOADDR"
echo "Subject: facsimile not received"
echo ""
echo "An attempt to receive facsimile on $DEVICE failed because:"
echo ""
echo " $MSG"
echo ""
echo ""
log/c$COMMID
else
fi
fi
cd $tiffile
$FAX2PDF "$FILE2" "$FILE2.pdf"
mv $FILE2.pdf $FILE3.pdf
Hylafax
Hylafax
Hylafax
Hylafax
Sim segui vc tem um conf para me mandar??????Acho que o meu está com problemas!!!
