Prezados Clientes,
Carta em Ingles aos nossos clientes L-com e HyperLink. Estamos respondendo a duvidas e perguntas atuais sobre nossos produtos.
"First, let me please explain to those of you who may not know. The company, HyperLink® Technologies, was purchased in late 2007 by L-Com® Corporation, a large distributor and manufacturer of RF components and systems in Andover, Massachusetts, USA (www.L-com.com). L-Com is committed to fully supporting the HyperLink® Brand and stands firmly behind all of its products in Quality, Reliability and Performance. You can be sure you will receive the same quality HyperLink® products you have always used in the future. We are not going away, we have just joined a larger company, L-Com®.
Considerable discussions have been posted regarding the HyperLink® Brand and other antennas being sold into the wireless market. Please be sure that if you purchase HyperLink® products you are buying the best antennas available for the price. We make this statement based on thousands of antennas in the field, operating reliably every day for customers around the world. HyperLink® quality is known to every installer and wireless provider as the quality antenna for their applications.
Hyperlink® designs and produces it's own antenna line as well as buying select models from trusted suppliers. The majority of antennas sold were designed and manufactured by Hyperlink. The antennas that are purchased have undergone a rigorous qualification regime to assure quality. Hyperlink requires these purchased antennas be modified by the Manufacturer to meet Hyperlink's requirements. Hyperlink has the experience to support the customer that is unmatched by anyone in the industry. Hyperlink designs and produces 100% of it's Amplifiers, Surge Protectors, Splitters, NEMA Enclosures and the majority of it's cable assemblies in Boca Raton Florida. Hyperlink also designed many of it's coaxial connectors to assure performance and quality.
Many of the antennas you see installed look similar in shape. This is because of the geometry of the antennas are important to their operation. Sector antennas for instance, operate in similar antennas configurations for beam widths and coverage to perform as required by the installer. A 90 degree sector panel antenna therefore look similar between most manufacturers. Appearance though can be deceiving and you need to look at the performance of the antennas in the field in similar applications. HyperLink® products have a proven record of high quality, excellent performance and fair prices to those who use and trust this brand.
Most of the antennas sold for the 2.4-2.5GHz and 4.9-5.8GHz base sector and infrastructure applications use similar mounting hardware and are mounted in similar fashions at most sites. It is not uncommon for an installer to see a replacement antenna fit the mounting hardware of the antenna he has just removed. If we were to take the two antennas apart and review the designs and how they are implemented, one would see differences in the layout, the quality of the components, and the grades of materials used to build the two antennas by two manufacturers.
We utilize the highest quality components and materials possible, at prices that are fair and representative of a high quality antenna for the applications they are designed to meet. If you purchase the HyperLink® Brand antennas you are assured of the quality, performance, and durability in the field. Please be assured there are differences in the antennas we develop and build from others on the market. They are unique and carry the HyperLink® name to distinguish them from the others available, so you will know you are installing the best systems possible for reliable performance for your customers.
We hope this answers the questions that have been raised and that we can continue to supply you with the best antennas you can purchase, at affordable prices for your customers."
Agradeçemos sua atenção e suas comunicaçoes. Envien seus comentarios ao nosso Gerente de Produtos, Karl Blomgren ao seu correio, kblomgren@hyperlinktech.com
Atenciosamente,
Ronald Swait
Inside Sales Representative- South America and International
L-Com Global Connectivity
Web site:www.l-com.com
** Be sure to check our latest specials updated monthly! **
** http://www.hyperlinktech.com/web/specials.php **
