Tentei instalar ontem o thunderCache mais ao inicializar o Squid aparece a seguinte mensagem:
squidFATAL: Bungled squid.conf line 253: url_rewrite_program /etc/squid/loader.php
Vou postar as Configurações:
Squid.conf
Thunder.confCódigo :# /etc/squid.conf http_port 3128 transparent hierarchy_stoplist cgi-bin ? acl QUERY urlpath_regex cgi-bin \? no_cache deny QUERY cache_mem 1024 MB maximum_object_size_in_memory 64 KB maximum_object_size 16 MB minimum_object_size 0 KB cache_swap_low 90 cache_swap_high 95 cache_dir ufs /var/spool/squid 40196 16 256 # Arquivo onde s�o guardados os logs de acesso do Squid. cache_access_log /var/log/squid/access.log visible_hostname kurumin # O e-mail que o Squid envia como senha ao acessar um servidor # FTP anonimo: ftp_user [email protected] refresh_pattern ^ftp: 15 20% 2280 refresh_pattern ^gopher: 15 0% 2280 refresh_pattern . 15 20% 2280 acl all src 0.0.0.0/0.0.0.0 acl manager proto cache_object acl localhost src 127.0.0.1/255.255.255.255 acl SSL_ports port 443 563 acl Safe_ports port 80 # http acl Safe_ports port 21 # ftp acl Safe_ports port 443 563 # https, snews acl Safe_ports port 70 # gopher acl Safe_ports port 210 # wais acl Safe_ports port 1025-65535 # unregistered ports acl Safe_ports port 280 # http-mgmt acl Safe_ports port 488 # gss-http acl Safe_ports port 591 # filemaker acl Safe_ports port 777 # multiling http acl Safe_ports port 901 # SWAT acl purge method PURGE acl CONNECT method CONNECT http_access allow manager localhost http_access deny manager http_access allow purge localhost http_access deny purge http_access deny !Safe_ports http_access deny CONNECT !SSL_ports http_access allow localhost acl bloqueados url_regex -i "/etc/squid/bloqueados" http_access deny bloqueados #ThunderCache #OPÇÕES DE REDIRECIONAMENTO url_rewrite_children 10 acl store_rewrite_list dstdomain -i "/etc/squid/thunder.lst" url_rewrite_access allow store_rewrite_list url_rewrite_access deny all url_rewrite_program /etc/squid/loader.php #nega cache local, para não haver duplicação acl localcache dstdomain 172.20.55.31 cache deny localcache # >> Controle de acesso << # Aqui voc� pode ativar a configura��o do Squid que o deixar� explicitamente # dispon�vel apenas para a faixa de endere�os da sua rede local, recusando # acessos provenientes de outras redes, mesmo que o firewall esteja desabilitado. # Configure a linha abaixo com a faixa de endere�os IP e a m�scara de # sub-rede (o 24 equivale � mascara 255.255.255.0) da sua rede local e deixe # tamb�m a linha http_access deny all (mais abaixo) descomentada. acl redelocal src 172.20.0.0/16 http_access allow redelocal http_access deny all #http_access allow all
Configurações:Código :<?php $cache_dir = "/var/www/thunder"; $disk_max = 98; // in percent $cache_scr = "/etc/squid"; $server_ip = "172.20.55.31"; $cache_url = "http://$server_ip/thunder"; $download_speed = 1024; // kbytes $logadd_on = false; $redir = "302:"; // keep empty if you need a internal rewriter $proxy_host = ""; // keep it empty if you dont need proxy $proxy_port = "3128"; // advanced params - IF YOU DONT KNOW, DONT TOUCH! $packet_size = 200; // in bytes $packet_delay = 2000; // time in micro second $download_timeout = 10; ?>
IP Servidor: 172.20.55.31
Rede dos CLientes: 172.20.55.0/24
Antes de tentar instalar o ThunderCache estava tudo funcionando ok! A tela de relatorio do thunder cache aparece sem problemas mas não aparece nenhuma informação adicional, ficando como se não houvesse uso. A navegação não funciona quando o redirecionamento pro squid é feito.
Infelizmente não posso aplicar o script feito por um de nossos amigos que automatiza as taferas. Segui o tuto do nosso amigo rodrigo manga na risca e mesmo assim este erro persiste.
Por favor socorro!!!!!!!!
Com o squid parado os clientes estão consumindo quase a banda toda fora do horário de Pico!
Obrigado a todos!
Citação
