Saiu a versão 3.24 do Mikrotik
http://www.mikrotik.com/download.html
What's new in 3.24:
*) added ability to run non RouterOS in MetaROUTER;
*) improved address-list and layer7 firewall feature support for smp systems;
*) special-login items can now be disabled;
*) fixed special-login to update used-by property of port;
*) fixed USB UPS monitoring on RB433UAH;
*) console - 'print' command reuses assigned item numbers;
*) fixed issue with Cisco BGP VPLS when used between 2 RouterOS devices;
*) console - 'print' commands have new option 'follow-only' that continuously
shows changes like the 'follow' option, but does not print all items
at the beginning;
*) api - 'follow' and 'follow-only' options of 'print' commands now work,
'.dead' property is reported for deleted items;
*) api - 'listen' command now is alias for 'print' with 'follow-only'
opriont set;
*) api - several commands running in parallel could produce intermixed
output, fixed;
*) console and api - fixed problem that caused property values sometimes to
incorrectly have value '(unknown)', this could happen when running
several console or api commands at once;
*) fixed BGP VPLS crash when site-id > 15 used somewhere in network;
*) changed BGP AS path number output format to ASPLAIN;
*) console - new scheduler tasks use trimmed effective user permissions as the
default value of policy, previously default value was "read,write,test";
*) added ttl matcher to ipv4 firewall;
*) improved dns cache not to allow other RRs in statically configured domains;
*) fixed vlan on bonding;
*) fixed bonding modes balance-alb and balance-tlb;
*) added per-connection-classifier matcher to firewall;
*) fixed wireless Hw. Fragmentation Threshold in WinBox;
*) user manager - added option to specify custom Return URL
for Authorize.Net payments;
*) user manager - write logs to syslog topic manager,account;
*) routing-test - support for per-VRF BGP instance redistribute settings;
*) routing-test - speed up BGP route processing;
*) routing-test - added routing-table configuration to RIP;
