http_port 5128
visible_hostname proxy1.raionet.com
hierarchy_stoplist cgi-bin ?
no_cache deny QUERY
memory_replacement_policy heap GDSF
cache_replacement_policy heap LFUDA
# LOGs
cache_store_log none
access_log none
cache_log none
pid_filename /var/run/squid1.pid
# ACLs
acl localhost src 127.0.0.1/32
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl CONNECT method CONNECT
# Permissão de acesso ao proxy
acl redelocal src 192.168.55.0/27
http_access deny manager
http_access deny !Safe_ports
http_access allow redelocal
# Memoria reservada para o cache
cache_mem 1024 MB
# Maximo tamanho dos arquivo cache na memoria
maximum_object_size_in_memory 256 KB
# Maximo tamanho dos arquivo cache no hd
maximum_object_size 100 MB
minimum_object_size 0 KB
# Regra que começa a esvaziar / Substituir
arquivos no cache em 90%
cache_swap_low 90
cache_swap_high 95
# Cache do squid
cache_dir aufs /var/spool/squid/1/1 81920 32 256
# Intervalos de tempos que o proxy verificara os arquivos dos site acessado
refresh_pattern ^ftp: 15 20% 4560
refresh_pattern ^gopher: 15 0% 4560
refresh_pattern . 15 20% 4560
