[Fri Sep 18 10:12:00 2009] index.cgi: Use of uninitialized value $line in split at sysstats-gen-lib.pl line 376.
2009/09/18 14:12:00 main::install_module(modules/fail2ban-0.8/fail2ban-lib.pl 60) warning : disable fail2ban module : unconfigured command name
2009/09/18 14:12:00 main::install_module(modules/mysql-0.13/mysql-lib.pl 79) warning : disable mysql module : can not find perl DBI module
2009/09/18 14:12:00 main::install_module(modules/snmp-0.7/snmp-lib.pl 68) warning : WARNING : the snmp module needs the Net::SNMP perl module or the snmpget command
[Fri Sep 18 10:12:01 2009] index.cgi: Use of uninitialized value $line in split at sysstats-gen-lib.pl line 376.
2009/09/18 14:12:01 main::install_module(modules/snort-0.9/snort-lib.pl 70) warning : disable snort module unconfigured command name
2009/09/18 14:12:01 main::tab_param_sensors(modules/lm_sensors-0.10/lm_sensors-lib.pl 459) warning : disable lm_sensors module : no parameters founds
2009/09/18 14:12:01 main::install_module(modules/samba-0.8/samba-lib.pl 61) warning : disable samba module : unconfigured command name
2009/09/18 14:12:01 main::install_module(modules/amavis-0.9/amavis-lib.pl 72) warning : disable amavis : unconfigured file
[Fri Sep 18 10:12:01 2009] index.cgi: Subroutine read_static_param redefined at modules/dns-0.6/dns-lib.pl line 395.
2009/09/18 14:12:01 main::install_module(modules/dns-0.6/dns-lib.pl 71) warning : disable dns module : unconfigured file
2009/09/18 14:12:02 main::check_db_uid(sysstats-rrd-lib.pl 906) info : mem : fix db_uid=3 (was 1)
2009/09/18 14:12:02 main::check_db_uid(sysstats-rrd-lib.pl 906) info : network : fix db_uid=3 (was 1)
2009/09/18 14:12:02 main::check_db_uid(sysstats-rrd-lib.pl 906) info : mailq : fix db_uid=4 (was 1)
2009/09/18 14:12:02 main::check_db_uid(sysstats-rrd-lib.pl 906) info : cpu : fix db_uid=2 (was 1)
2009/09/18 14:12:02 main::check_db_uid(sysstats-rrd-lib.pl 906) info : process : fix db_uid=3 (was 1)
2009/09/18 14:12:02 main::get_dist_version(./sysstats-lib.pl 1331) warning : missing library LWP : can not get sourceforge versions list
[Fri Sep 18 10:12:26 2009] edit_module.cgi: Use of uninitialized value in concatenation (.) or string at modules/fail2ban-0.8/fail2ban-lib.pl line 519.
2009/09/18 14:12:36 main::get_dist_version(./sysstats-lib.pl 1331) warning : missing library LWP : can not get sourceforge versions list
