// named.conf
// Provided by Red Hat bind package to configure the ISC BIND named(8) DNS
// server as a caching only nameserver (as a localhost DNS resolver only).
// See /usr/share/doc/bind*/sample/ for example named configuration files.
options {
listen-on port 53 { 192.168.60.0/24; 192.168.70.0/24; 127.0.0.1; };
directory "/var/named";
dump-file "/var/named/data/cache_dump.db";
statistics-file "/var/named/data/named_stats.txt";
memstatistics-file "/var/named/data/named_mem_stats.txt";
allow-query { 192.168.60.0/24; 192.168.70.0/24; localhost; };
recursion yes;
tcp-clients 1000;
version "Not Available";
recursive-clients 1000;
forwarders { 200.175.5.139; 189.38.95.95; 200.176.2.12; 208.67.222.222; 200.225.157.104; 201.10.128.2; 200.176.2.10; 189.38.95.96; 208.67.220.220; 200.225.157.105; 200.175.182.139; 201.10.120.3; 200.192.112.8; };
logging {
channel default_debug {
file "data/named.run";
severity dynamic;
zone "." IN {
type hint;
file "named.ca";
include "/etc/named.rfc1912.zones";
