Pessoal seguinte, quando tento acessar o webmail do squirrelmail aparece esse codigo ai:
<?php
* index.php
* Redirects to the login page.
* @copyright © 1999-2007 The SquirrelMail Project Team
* @license GNU General Public License Versions | Open Source Initiative GNU Public License
* @version $Id: index.php 12127 2007-01-13 20:07:24Z kink $
* @package squirrelmail
// Are we configured yet?
if( ! file_exists ( 'config/config.php' ) ) {
echo '<html><body><p><strong>ERROR:</strong> Config file ' .
'"<tt>config/config.php</tt>" not found. You need to ' .
'configure SquirrelMail before you can use it.</p></body></html>';
exit;
// If we are, go ahead to the login page.
header('Location: src/login.php');
Alguem poderia me ajudar?
Abraços!!!
