-  Problema meu proxy
 Problema meu proxy
							Gostaria ajuda por favor urgente seguinte eu tenho em torno 12 clientes de lanhouses acessando meu proxy quando eles estao acessando meu proxy simultaniamente da erro e trava meu squid:
Message from syslogd@proxy1 at Tue Oct  6 10:12:53 2009 ...
proxy1 kernel: Oops: 0000 [#1]
proxy1 kernel: SMP
proxy1 kernel: CPU:    0
proxy1 kernel: EIP:    0060:[<c05e6658>]    Not tainted VLI
proxy1 kernel: EFLAGS: 00010246   (2.6.22.14-72 #1)
proxy1 kernel: EIP is at __ip_route_output_key+0x428/0x739
proxy1 kernel: eax: 5d1484e0   ebx: 00000000   ecx: b33a5ac9   edx: 000000e0
proxy1 kernel: esi: f6d08e54   edi: 00000000   ebp: f760d7c0   esp: f6d08d30
proxy1 kernel: ds: 007b   es: 007b   fs: 00d8  gs: 0033  ss: 0068
proxy1 kernel: Process squid (pid: 6847, ti=f6d08000 task=c2d43800 task.ti=f6d08000)
proxy1 kernel: Stack: 0000005e f6d08e90 00000000 00000000 c05cbed0 c05c9b73 00000040 f7817000
proxy1 kernel:        f781706c c05cc2a8 00000000 00000000 00000001 00000000 5d1484e0 b33a5ac9
proxy1 kernel:        00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
proxy1 kernel: Call Trace:
proxy1 kernel:  [<c05cbed0>] skb_copy_datagram_iovec+0x46/0x1d1
proxy1 kernel:  [<c05c9b73>] skb_dequeue+0x39/0x3f
proxy1 kernel:  [<c05cc2a8>] skb_recv_datagram+0x75/0x1a9
proxy1 kernel:  [<c05e697d>] ip_route_output_flow+0x14/0x1f9
proxy1 kernel:  [<c05c50f2>] sock_recvmsg+0xec/0x107
proxy1 kernel:  [<c06021b8>] tcp_v4_connect+0x199/0x5e3
proxy1 kernel:  [<c0438765>] autoremove_wake_function+0x0/0x35
proxy1 kernel:  [<c04edb18>] copy_to_user+0x34/0x48
proxy1 kernel:  [<c060d7db>] inet_stream_connect+0x7f/0x205
proxy1 kernel:  [<c04ed8d8>] copy_from_user+0x32/0x5e
proxy1 kernel:  [<c05c5c17>] sys_connect+0x82/0xad
proxy1 kernel:  [<c04301ff>] lock_timer_base+0x19/0x35
proxy1 kernel:  [<c043025f>] try_to_del_timer_sync+0x44/0x4a
proxy1 kernel:  [<c043026f>] del_timer_sync+0xa/0x14
proxy1 kernel:  [<c062f0a2>] schedule_timeout+0x79/0x8f
proxy1 kernel:  [<c05c6460>] sys_socketcall+0xac/0x261
proxy1 kernel:  [<c0404f5e>] syscall_call+0x7/0xb
proxy1 kernel:  =======================
proxy1 kernel: Code: 89 c2 81 e2 f0 00 00 00 81 fa e0 00 00 00 75 07 c6 44 24 6a 05 eb 14 81 fa f0 00 00 00 0f 84 cb 02 00 00 84 c0 0f 84 c3 02 00 00 <f6> 83 b8 00 00 00 08 74 08 81 4c 24 08 00 00 00 80 8b ab 08 01
proxy1 kernel: EIP: [<c05e6658>] __ip_route_output_key+0x428/0x739 SS:ESP 0068:f6d08d30
ja troquei memoria HDD nada para problema esse erro
por favor pessoal se alguem ja teve esse tipo de problema me der luz por favor ok
							Posta a conf do seu squid aii....
