- Não boot Unix
Não boot Unix
PessoALL,
Tenho um server Unix não sei se alguém pode me ajudar mas acontece o seguinte a máquina não esta dando boot , mas sim desligando fisicamente, sem nenhuma mensagem de advertência na console.
Pelo que pude detectar a ventuinha está funcionando e a temparatura da máquina está normal (sensação externa que observei). Fiz também uma experiência de troca de tomada e não tive resultado.
Já aconteceu isso com alguém?
Valeww
Abaixo as ultimas 200 linhas do messages do nosso servidor Unix.
Feb 9 16:24:25 rydersbc2 vmunix: ace1 at eisa0
Feb 9 16:24:25 rydersbc2 vmunix: lp0 at eisa0
Feb 9 16:24:25 rydersbc2 vmunix: fdi0 at eisa0
Feb 9 16:24:25 rydersbc2 vmunix: fd0 at fdi0 unit 0
Feb 9 16:24:25 rydersbc2 vmunix: trio0 at pci0 slot 2
Feb 9 16:24:25 rydersbc2 vmunix: trio0: S3 Trio64V+ (SVGA) Plug-N-Play, 2.0 Mb
Feb 9 16:24:25 rydersbc2 vmunix: isp0 at pci0 slot 3
Feb 9 16:24:25 rydersbc2 vmunix: isp0: QLOGIC ISP1040B/V2
Feb 9 16:24:25 rydersbc2 vmunix: isp0: Firmware revision 5.57 (loaded by console)
Feb 9 16:24:25 rydersbc2 vmunix: isp0: Fast RAM timing enabled.
Feb 9 16:24:25 rydersbc2 vmunix: scsi1 at isp0 slot 0
Feb 9 16:24:25 rydersbc2 vmunix: pza0 at pci0 slot 4
Feb 9 16:24:25 rydersbc2 vmunix: pza0 firmware version: DEC P01 A11
Feb 9 16:24:25 rydersbc2 vmunix: scsi2 at pza0 slot 0
Feb 9 16:24:25 rydersbc2 vmunix: Created FRU table binary error log packet
Feb 9 16:24:25 rydersbc2 vmunix: lvm0: configured.
Feb 9 16:24:25 rydersbc2 vmunix: lvm1: configured.
Feb 9 16:24:25 rydersbc2 vmunix: kernel console: trio0
Feb 9 16:24:25 rydersbc2 vmunix: dli: configured
Feb 9 16:24:25 rydersbc2 vmunix: clubase: configured
Feb 9 16:24:25 rydersbc2 vmunix: ADVFS: using 2322 buffers containing 18.14 megabytes of memory
Feb 9 16:24:25 rydersbc2 vmunix: vm_swap_init: vm_swapon for /dev/rz8b device failed
Feb 9 16:24:25 rydersbc2 vmunix: vm_swap_init: swap is set to lazy (over commitment) mode
Feb 9 16:24:25 rydersbc2 vmunix: Starting secondary cpu 1
Feb 9 16:24:46 rydersbc2 vmunix: Environmental Monitoring Subsystem Configured.
Feb 9 16:24:47 rydersbc2 vmunix: SuperLAT. Copyright 1994 Meridian Technology Corp. All rights reserved.
Feb 10 09:03:37 rydersbc2 vmunix: Alpha boot: available memory from 0x21aa000 to 0x63ffe000
Feb 10 09:03:37 rydersbc2 vmunix: Digital UNIX V4.0D (Rev. 878); Wed Dec 10 18:36:19 EDT 2003
Feb 10 09:03:37 rydersbc2 vmunix: physical memory = 256.00 megabytes.
Feb 10 09:03:37 rydersbc2 vmunix: available memory = 222.32 megabytes.
Feb 10 09:03:37 rydersbc2 vmunix: using 238 buffers containing 1.85 megabytes of memory
Feb 10 09:03:37 rydersbc2 vmunix: Master cpu at slot 0.
Feb 10 09:03:37 rydersbc2 vmunix: Firmware revision: 5.3
Feb 10 09:03:37 rydersbc2 vmunix: PALcode: Digital UNIX version 1.21
Feb 10 09:03:37 rydersbc2 vmunix: AlphaServer 1200 5/533 4MB
Feb 10 09:03:37 rydersbc2 vmunix: pci1 at mcbus0 slot 5
Feb 10 09:03:37 rydersbc2 vmunix: psiop0 at pci1 slot 1
Feb 10 09:03:37 rydersbc2 vmunix: Loading SIOP: script c0001400, reg 7fb7d00, data c000b320
Feb 10 09:03:37 rydersbc2 vmunix: scsi0 at psiop0 slot 0
Feb 10 09:03:37 rydersbc2 vmunix: rz4 at scsi0 target 4 lun 0 (LID=0) (DEC RRD46 (C) DEC 1337)
Feb 10 09:03:37 rydersbc2 vmunix: tz5 at scsi0 target 5 lun 0 (LID=1) (DEC TLZ10 (C) DEC 02ab)
Feb 10 09:03:37 rydersbc2 vmunix: Initializing xcr0. Please wait....
Feb 10 09:03:37 rydersbc2 vmunix: xcr0 at pci1 slot 2
Feb 10 09:03:37 rydersbc2 vmunix: re0 at xcr0 unit 0 (unit status = ONLINE, raid level = 5)
Feb 10 09:03:37 rydersbc2 vmunix: (WRITE BACK cache operation SUPPORTED if battery backup enabled)
Feb 10 09:03:37 rydersbc2 vmunix: re1 at xcr0 unit 1 (unit status = ONLINE, raid level = 5)
Feb 10 09:03:37 rydersbc2 vmunix: re2 at xcr0 unit 2 (unit status = ONLINE, raid level = 5)
Feb 10 09:03:37 rydersbc2 vmunix: tu0: DECchip 21140: Revision: 2.2
Feb 10 09:03:37 rydersbc2 vmunix: tu0: auto negotiation capable device
Feb 10 09:03:37 rydersbc2 vmunix: tu0 at pci1 slot 4
Feb 10 09:03:37 rydersbc2 vmunix: tu0: DEC TULIP (10/100) Ethernet Interface, hardware address: 00-00-F8-07-FD-05
Feb 10 09:03:37 rydersbc2 vmunix: tu0: auto negotiation off: selecting 100BaseTX (UTP) port: half duplex
Feb 10 09:03:37 rydersbc2 vmunix: gpc0 at eisa0
Feb 10 09:03:37 rydersbc2 vmunix: pci0 at mcbus0 slot 4
Feb 10 09:03:37 rydersbc2 vmunix: eisa0 at pci0
Feb 10 09:03:37 rydersbc2 vmunix: ace0 at eisa0
Feb 10 09:03:37 rydersbc2 vmunix: ace1 at eisa0
Feb 10 09:03:37 rydersbc2 vmunix: lp0 at eisa0
Feb 10 09:03:37 rydersbc2 vmunix: fdi0 at eisa0
Feb 10 09:03:37 rydersbc2 vmunix: fd0 at fdi0 unit 0
Feb 10 09:03:37 rydersbc2 vmunix: trio0 at pci0 slot 2
Feb 10 09:03:37 rydersbc2 vmunix: trio0: S3 Trio64V+ (SVGA) Plug-N-Play, 2.0 Mb
Feb 10 09:03:37 rydersbc2 vmunix: isp0 at pci0 slot 3
Feb 10 09:03:37 rydersbc2 vmunix: isp0: QLOGIC ISP1040B/V2
Feb 10 09:03:37 rydersbc2 vmunix: isp0: Firmware revision 5.57 (loaded by console)
Feb 10 09:03:37 rydersbc2 vmunix: isp0: Fast RAM timing enabled.
Feb 10 09:03:37 rydersbc2 vmunix: scsi1 at isp0 slot 0
Feb 10 09:03:37 rydersbc2 vmunix: pza0 at pci0 slot 4
Feb 10 09:03:37 rydersbc2 vmunix: pza0 firmware version: DEC P01 A11
Feb 10 09:03:37 rydersbc2 vmunix: scsi2 at pza0 slot 0
Feb 10 09:03:37 rydersbc2 vmunix: Created FRU table binary error log packet
Feb 10 09:03:37 rydersbc2 vmunix: lvm0: configured.
Feb 10 09:03:37 rydersbc2 vmunix: lvm1: configured.
Feb 10 09:03:37 rydersbc2 vmunix: kernel console: trio0
Feb 10 09:03:37 rydersbc2 vmunix: dli: configured
Feb 10 09:03:37 rydersbc2 vmunix: clubase: configured
Feb 10 09:03:37 rydersbc2 vmunix: ADVFS: using 2322 buffers containing 18.14 megabytes of memory
Feb 10 09:03:37 rydersbc2 vmunix: vm_swap_init: vm_swapon for /dev/rz8b device failed
Feb 10 09:03:37 rydersbc2 vmunix: vm_swap_init: swap is set to lazy (over commitment) mode
Feb 10 09:03:37 rydersbc2 vmunix: Starting secondary cpu 1
Feb 10 09:03:58 rydersbc2 vmunix: Environmental Monitoring Subsystem Configured.
Feb 10 09:03:59 rydersbc2 vmunix: SuperLAT. Copyright 1994 Meridian Technology Corp. All rights reserved.
Feb 10 10:39:14 rydersbc2 vmunix: Alpha boot: available memory from 0x21aa000 to 0x63ffe000
Feb 10 10:39:14 rydersbc2 vmunix: Digital UNIX V4.0D (Rev. 878); Wed Dec 10 18:36:19 EDT 2003
Feb 10 10:39:14 rydersbc2 vmunix: physical memory = 256.00 megabytes.
Feb 10 10:39:14 rydersbc2 vmunix: available memory = 222.32 megabytes.
Feb 10 10:39:14 rydersbc2 vmunix: using 238 buffers containing 1.85 megabytes of memory
Feb 10 10:39:14 rydersbc2 vmunix: Master cpu at slot 0.
Feb 10 10:39:14 rydersbc2 vmunix: Firmware revision: 5.3
Feb 10 10:39:14 rydersbc2 vmunix: PALcode: Digital UNIX version 1.21
Feb 10 10:39:14 rydersbc2 vmunix: AlphaServer 1200 5/533 4MB
Feb 10 10:39:14 rydersbc2 vmunix: pci1 at mcbus0 slot 5
Feb 10 10:39:14 rydersbc2 vmunix: psiop0 at pci1 slot 1
Feb 10 10:39:14 rydersbc2 vmunix: Loading SIOP: script c0001400, reg 7fb7d00, data c000b320
Feb 10 10:39:14 rydersbc2 vmunix: scsi0 at psiop0 slot 0
Feb 10 10:39:14 rydersbc2 vmunix: rz4 at scsi0 target 4 lun 0 (LID=0) (DEC RRD46 (C) DEC 1337)
Feb 10 10:39:14 rydersbc2 vmunix: tz5 at scsi0 target 5 lun 0 (LID=1) (DEC TLZ10 (C) DEC 02ab)
Feb 10 10:39:14 rydersbc2 vmunix: Initializing xcr0. Please wait....
Feb 10 10:39:14 rydersbc2 vmunix: xcr0 at pci1 slot 2
Feb 10 10:39:14 rydersbc2 vmunix: re0 at xcr0 unit 0 (unit status = ONLINE, raid level = 5)
Feb 10 10:39:14 rydersbc2 vmunix: (WRITE BACK cache operation SUPPORTED if battery backup enabled)
Feb 10 10:39:14 rydersbc2 vmunix: re1 at xcr0 unit 1 (unit status = ONLINE, raid level = 5)
Feb 10 10:39:14 rydersbc2 vmunix: re2 at xcr0 unit 2 (unit status = ONLINE, raid level = 5)
Feb 10 10:39:14 rydersbc2 vmunix: tu0: DECchip 21140: Revision: 2.2
Feb 10 10:39:14 rydersbc2 vmunix: tu0: auto negotiation capable device
Feb 10 10:39:14 rydersbc2 vmunix: tu0 at pci1 slot 4
Feb 10 10:39:14 rydersbc2 vmunix: tu0: DEC TULIP (10/100) Ethernet Interface, hardware address: 00-00-F8-07-FD-05
Feb 10 10:39:14 rydersbc2 vmunix: tu0: auto negotiation off: selecting 100BaseTX (UTP) port: half duplex
Feb 10 10:39:14 rydersbc2 vmunix: gpc0 at eisa0
Feb 10 10:39:14 rydersbc2 vmunix: pci0 at mcbus0 slot 4
Feb 10 10:39:14 rydersbc2 vmunix: eisa0 at pci0
Feb 10 10:39:14 rydersbc2 vmunix: ace0 at eisa0
Feb 10 10:39:14 rydersbc2 vmunix: ace1 at eisa0
Feb 10 10:39:14 rydersbc2 vmunix: lp0 at eisa0
Feb 10 10:39:14 rydersbc2 vmunix: fdi0 at eisa0
Feb 10 10:39:14 rydersbc2 vmunix: fd0 at fdi0 unit 0
Feb 10 10:39:14 rydersbc2 vmunix: trio0 at pci0 slot 2
Feb 10 10:39:14 rydersbc2 vmunix: trio0: S3 Trio64V+ (SVGA) Plug-N-Play, 2.0 Mb
Feb 10 10:39:14 rydersbc2 vmunix: isp0 at pci0 slot 3
Feb 10 10:39:14 rydersbc2 vmunix: isp0: QLOGIC ISP1040B/V2
Feb 10 10:39:14 rydersbc2 vmunix: isp0: Firmware revision 5.57 (loaded by console)
Feb 10 10:39:14 rydersbc2 vmunix: isp0: Fast RAM timing enabled.
Feb 10 10:39:14 rydersbc2 vmunix: scsi1 at isp0 slot 0
Feb 10 10:39:14 rydersbc2 vmunix: pza0 at pci0 slot 4
Feb 10 10:39:14 rydersbc2 vmunix: pza0 firmware version: DEC P01 A11
Feb 10 10:39:14 rydersbc2 vmunix: scsi2 at pza0 slot 0
Feb 10 10:39:14 rydersbc2 vmunix: Created FRU table binary error log packet
Feb 10 10:39:14 rydersbc2 vmunix: lvm0: configured.
Feb 10 10:39:14 rydersbc2 vmunix: lvm1: configured.
Feb 10 10:39:14 rydersbc2 vmunix: kernel console: trio0
Feb 10 10:39:14 rydersbc2 vmunix: dli: configured
Feb 10 10:39:14 rydersbc2 vmunix: clubase: configured
Feb 10 10:39:14 rydersbc2 vmunix: ADVFS: using 2322 buffers containing 18.14 megabytes of memory
Feb 10 10:39:14 rydersbc2 vmunix: vm_swap_init: vm_swapon for /dev/rz8b device failed
Feb 10 10:39:14 rydersbc2 vmunix: vm_swap_init: swap is set to lazy (over commitment) mode
Feb 10 10:39:14 rydersbc2 vmunix: Starting secondary cpu 1
Feb 10 10:39:36 rydersbc2 vmunix: Environmental Monitoring Subsystem Configured.
Feb 10 10:39:36 rydersbc2 vmunix: SuperLAT. Copyright 1994 Meridian Technology Corp. All rights reserved.
Feb 10 12:46:28 rydersbc2 vmunix: Alpha boot: available memory from 0x21aa000 to 0x63ffe000
Feb 10 12:46:28 rydersbc2 vmunix: Digital UNIX V4.0D (Rev. 878); Wed Dec 10 18:36:19 EDT 2003
Feb 10 12:46:28 rydersbc2 vmunix: physical memory = 256.00 megabytes.
Feb 10 12:46:28 rydersbc2 vmunix: available memory = 222.32 megabytes.
Feb 10 12:46:28 rydersbc2 vmunix: using 238 buffers containing 1.85 megabytes of memory
Feb 10 12:46:28 rydersbc2 vmunix: Master cpu at slot 0.
Feb 10 12:46:28 rydersbc2 vmunix: Firmware revision: 5.3
Feb 10 12:46:28 rydersbc2 vmunix: PALcode: Digital UNIX version 1.21
Feb 10 12:46:28 rydersbc2 vmunix: AlphaServer 1200 5/533 4MB
Feb 10 12:46:28 rydersbc2 vmunix: pci1 at mcbus0 slot 5
Feb 10 12:46:28 rydersbc2 vmunix: psiop0 at pci1 slot 1
Feb 10 12:46:28 rydersbc2 vmunix: Loading SIOP: script c0001400, reg 7fb7d00, data c000b320
Feb 10 12:46:28 rydersbc2 vmunix: scsi0 at psiop0 slot 0
Feb 10 12:46:28 rydersbc2 vmunix: rz4 at scsi0 target 4 lun 0 (LID=0) (DEC RRD46 (C) DEC 1337)
Feb 10 12:46:28 rydersbc2 vmunix: tz5 at scsi0 target 5 lun 0 (LID=1) (DEC TLZ10 (C) DEC 02ab)
Feb 10 12:46:28 rydersbc2 vmunix: Initializing xcr0. Please wait....
Feb 10 12:46:28 rydersbc2 vmunix: xcr0 at pci1 slot 2
Feb 10 12:46:28 rydersbc2 vmunix: re0 at xcr0 unit 0 (unit status = ONLINE, raid level = 5)
Feb 10 12:46:28 rydersbc2 vmunix: (WRITE BACK cache operation SUPPORTED if battery backup enabled)
Feb 10 12:46:28 rydersbc2 vmunix: re1 at xcr0 unit 1 (unit status = ONLINE, raid level = 5)
Feb 10 12:46:28 rydersbc2 vmunix: re2 at xcr0 unit 2 (unit status = ONLINE, raid level = 5)
Feb 10 12:46:28 rydersbc2 vmunix: tu0: DECchip 21140: Revision: 2.2
Feb 10 12:46:28 rydersbc2 vmunix: tu0: auto negotiation capable device
Feb 10 12:46:28 rydersbc2 vmunix: tu0 at pci1 slot 4
Feb 10 12:46:28 rydersbc2 vmunix: tu0: DEC TULIP (10/100) Ethernet Interface, hardware address: 00-00-F8-07-FD-05
Feb 10 12:46:28 rydersbc2 vmunix: tu0: auto negotiation off: selecting 100BaseTX (UTP) port: half duplex
Feb 10 12:46:28 rydersbc2 vmunix: gpc0 at eisa0
Feb 10 12:46:28 rydersbc2 vmunix: pci0 at mcbus0 slot 4
Feb 10 12:46:28 rydersbc2 vmunix: eisa0 at pci0
Feb 10 12:46:28 rydersbc2 vmunix: ace0 at eisa0
Feb 10 12:46:28 rydersbc2 vmunix: ace1 at eisa0
Feb 10 12:46:28 rydersbc2 vmunix: lp0 at eisa0
Feb 10 12:46:28 rydersbc2 vmunix: fdi0 at eisa0
Feb 10 12:46:28 rydersbc2 vmunix: fd0 at fdi0 unit 0
Feb 10 12:46:28 rydersbc2 vmunix: trio0 at pci0 slot 2
Feb 10 12:46:28 rydersbc2 vmunix: trio0: S3 Trio64V+ (SVGA) Plug-N-Play, 2.0 Mb
Feb 10 12:46:28 rydersbc2 vmunix: isp0 at pci0 slot 3
Feb 10 12:46:28 rydersbc2 vmunix: isp0: QLOGIC ISP1040B/V2
Feb 10 12:46:28 rydersbc2 vmunix: isp0: Firmware revision 5.57 (loaded by console)
Feb 10 12:46:28 rydersbc2 vmunix: isp0: Fast RAM timing enabled.
Feb 10 12:46:28 rydersbc2 vmunix: scsi1 at isp0 slot 0
Feb 10 12:46:28 rydersbc2 vmunix: pza0 at pci0 slot 4
Feb 10 12:46:28 rydersbc2 vmunix: pza0 firmware version: DEC P01 A11
Feb 10 12:46:28 rydersbc2 vmunix: scsi2 at pza0 slot 0
Feb 10 12:46:28 rydersbc2 vmunix: Created FRU table binary error log packet
Feb 10 12:46:28 rydersbc2 vmunix: lvm0: configured.
Feb 10 12:46:28 rydersbc2 vmunix: lvm1: configured.
Feb 10 12:46:28 rydersbc2 vmunix: kernel console: trio0
Feb 10 12:46:28 rydersbc2 vmunix: dli: configured
Feb 10 12:46:28 rydersbc2 vmunix: clubase: configured
Feb 10 12:46:28 rydersbc2 vmunix: ADVFS: using 2322 buffers containing 18.14 megabytes of memory
Feb 10 12:46:28 rydersbc2 vmunix: vm_swap_init: vm_swapon for /dev/rz8b device failed
Feb 10 12:46:28 rydersbc2 vmunix: vm_swap_init: swap is set to lazy (over commitment) mode
Feb 10 12:46:28 rydersbc2 vmunix: Starting secondary cpu 1
Feb 10 12:46:49 rydersbc2 vmunix: Environmental Monitoring Subsystem Configured.
Feb 10 12:46:50 rydersbc2 vmunix: SuperLAT. Copyright 1994 Meridian Technology Corp. All rights reserved.
Não boot Unix
primeiro de tudo, vai poluir o fórum dos outros, que é isso meu amigo.. devagar...
segundo, sensação externa nada, abre a máquina e vê se o cooler tá legal...
terceiro, vc não tem um disquete de arranque???
abre e dá uma olhada no cooler e verifica se ela tá rodando legal... pode ser superaquecimento.... uma graxa ajuda... quer dizer;.... pasta térmica.. vê lá e depois posta aí... só que posta uma vez apenas viu....
Não boot Unix
Ai kra desespero do kramba,
concordo com nosso amigo, faz o seguinte teste, abra a máquina e veja o coller. Verifique se na sua tomada a tensão esta correta utilize o voltimetro, depois poste aqui.
Não boot Unix
Cara num to poluindo o forum coisa alguma... isso se chama log... conhece... ???
Mas muito obrigado pela ajuda....
Não boot Unix
sem comentários, vê o cooler lá e boa vai... precisando estamos aí pra ajudar os necessitados e os mau educados....
