- Nvidia driver no debian
Recompilei o Kernel, to rodando agora o 2.6.2 a porcaria do driver da nvidia
continua alegando que não determinou a versão do kernel, repito to rodando o
Debian R2, kernel 2.6.2 minha placa de video é uma fx5200 to tentando
instalar o driver da nvidia e o driver me retorna a seguinte msg de erro.
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Feb 16 09:10:57 2004
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
no precompiled interface: false
no ncurses color : false
query latest driver ver : false
OpenGL header files : false
no questions : false
silent : false
XFree86 install prefix : /usr/X11R6
OpenGL install prefix : /usr
Installer install prefix: /usr
kernel source path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp site : ftp://download.nvidia.com
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you
li
ke the installer to attempt to download a kernel interface for your
kernel f
rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this
means
that the installer will need to compile a new kernel interface.
-> Kernel source path: '/usr/src/linux'
-> Performing cc_version_check with CC="cc".
ERROR: Unable to determine the NVIDIA kernel module filename.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find
suggestions
on fixing installation problems in the README available on the Linux
driver download page at www.nvidia.com.
Isso é por que o driver da nvidea está compilado para o kernel 2.4
Tente verificar se este driver já não está imbutido no kernel 2.6
