Estou com um moden Cisco 877 que não consigo fazelo funcionar de manira alguma, quam uso ele em bridge, e tento discar meu ADSL (Oi Velox) Recebo a mensagem de login e senha incorretos, na verdade queria fazer-lo funcionar em modulo router se se ele funcionaar em bridge ja adiantaria minha vida bastante.
Vou deixar minhas configuracões logo a baixo pra que alguem com mas esperiência que eu possa dar uma olhada.
Desde de já grato!
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname ADSL_ROUTER
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret <Minha senha>
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
resource policy
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
ip name-server 4.2.2.1
ip name-server 4.2.2.2
interface ATM0
no shutdown
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no shutdown
no snmp trap link-status
pvc 0/33
encapsulation aal5snap ppp dialer ß ( desconfio que o erro esteja aqui mas não consigo mudar)
dialer pool-member 1
interface FastEthernet0
no shutdown
interface FastEthernet1
no shutdown
interface FastEthernet2
no shutdown
interface FastEthernet3
no shutdown
interface Vlan1
no shutdown
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect DEFAULT100 out
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname <[email protected]>
ppp chap password < DDD+meutelefone >
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!
line con 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
transport input telnet
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Citação
