Galera boa noite a todos, to com o seguinte problema.
Uso o mikrotik v. 3,30 configurei para trabalhar com web - proxy full mais nao funcionou.
segue aqui minhas configurações para olharem e analisarem o que pode está errado.
/ip proxy
set always-from-cache=no cache-administrator="Site nao disponivel no momento." cache-hit-dscp=4 cache-on-disk=yes \
enabled=yes max-cache-size=unlimited max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=0.0.0.0 parent-proxy-port=0 port=3128 serialize-connections=no src-address=0.0.0.0
/ip firewall mangle
add action=mark-connection chain=output comment="CACHE FULL" content="X-Cache: HIT" disabled=no new-connection-mark=\
conn_squid-up passthrough=yes protocol=tcp src-port=3128
add action=mark-packet chain=output comment="" connection-mark=conn_squid-up disabled=no new-packet-mark=pacotes_squid-up \
passthrough=yes
add action=mark-connection chain=prerouting comment="" disabled=no dst-port=3128 new-connection-mark=conn_squid-down \
add action=mark-packet chain=prerouting comment="" connection-mark=conn_squid-down disabled=no new-packet-mark=\
pacotes_squid-down passthrough=yes
/ip firewall nat
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=no
add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=no src-address=192.168.170.0/24
add action=masquerade chain=srcnat comment=Full disabled=no src-address=192.168.170.150-192.168.170.200
add action=accept chain=dstnat comment=aceita_webmikrotik disabled=no dst-address=187.61.9.240/28 protocol=tcp
add action=dst-nat chain=pre-hotspot comment=mensagem_pendencia disabled=no dst-address=!187.61.9.240/28 protocol=tcp \
src-address-list=pendencia to-addresses=187.61.9.242 to-ports=40947
add action=dst-nat chain=pre-hotspot comment=mensagem_bloqueio disabled=no dst-address=!187.61.9.240/28 protocol=tcp \
src-address-list=bloqueio to-addresses=187.61.9.242 to-ports=40948
add action=dst-nat chain=dstnat comment=mensagem_pendencia disabled=no dst-address=!187.61.9.240/28 protocol=tcp \
add action=dst-nat chain=dstnat comment=mensagem_bloqueio disabled=no dst-address=!187.61.9.240/28 protocol=tcp \
add action=redirect chain=dstnat comment="" disabled=yes dst-port=80 in-interface="INSIDNET CLIENTES" protocol=tcp \
to-ports=3128
add action=redirect chain=dstnat comment="=\"redirecionamento porta 80 para webproxy 3128\" disabled=no\r\
\n" disabled=no dst-port=80 protocol=tcp src-address=192.168.170.0/24 to-ports=3128
add action=masquerade chain=srcnat comment=faixa_padrao disabled=no src-address=10.0.0.1-10.0.255.253
add action=masquerade chain=srcnat comment=Insidnet disabled=no src-address=192.168.170.50-192.168.170.100
add action=masquerade chain=srcnat comment=Economico disabled=no src-address=192.168.170.205-192.168.170.225
add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=no out-interface=LINK src-address=\
192.168.170.0/24
/ip firewall filter
add action=drop chain=input comment="BLOQUEI DE PROXY EXTERNO" disabled=no dst-port=3128 in-interface=LINK protocol=tcp
add action=accept chain=input comment="ACEITAR CONEXOES PROXY" disabled=no dst-port=3128 protocol=tcp
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=3M name=CACHE-FULL-Download \
packet-mark=pacotes_squid-down parent=global-in priority=1 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=3M name=CACHE-FULL-Upload packet-mark=\
pacotes_squid-up parent=global-out priority=1 queue=default
Galera nao sei o que está acontecendo, só sei que está configurado o cache de navegação funciona mais não está full e além do mais não está funcionando a função de armazenamento de download.
Espero que me ajudem pois já pesquisei demais e não encontrei soluçao.
Citação
