Tenho 1 enlace de 33Km com 3 pontos.
Ponto A>B (30KM):
2 Radios ZA-5000 11a 54Mbps
2 antenas Zirok de 23dbi 5.8
Cabo LMR-400 de 2 metros
CFG:
Operating Mode - Bridge Mode
Channel / Frequency 149/5.745HGHz
Data Rate Best
Output Power Full
RTS Threshold (0-2346) 2346
Fragmentation Threshold (256-2346) 2346
Super A Off
Beacon Interval (20-1000) 150ms
DTIM Interval (1-255) 1
Broadcast Wireless Network Name (SSID) yes
Enable Wireless Client Security Separator no
Buzzer Switch off
Operating Mode Wireless Point-to-Point Bridge
Sem Criptografia, ele somente se comunica com mac addres um do outro.
Remote MAC Elapsed Time Tx Pkt Num Rx Pkt Num Local Signal Level Remote Signal Level
7 111 111 -67dBm / 100% -68dBm / 100% RF Cable Loss(0-10) dB Local Antenna Gain(0-99) dBi Remote Antenna Gain(0-99) dBi Test Interval (1-60000) ms Test Packet Size (64-1514) byte Test Time (60-86400) s
Este link desce da torre para 1 swith 3com e sobe novamente para o outro radio.
Ponto B>C (3KM):
1 Rádio Tranzeo 802.11a (5 GHz)Tr6 Router
Antena Zirok 26.5 dBi Antenna
Cabo LMR 400 2 metros
Wireless Settings
Infrastructure Station
Access Point
Wireless Mode
Visible Invisible
Visibility Status Outdoor Indoor
Location CH 56 - 5.28 GHzCH 60 - 5.3 GHzCH 64 - 5.32 GHzCH 149 - 5.745 GHzCH 153 - 5.765 GHzCH 157 - 5.785 GHzCH 161 - 5.805 GHzCH 165 - 5.825 GHzCH 152 - 5.76 GHz - TurboCH 160 - 5.8 GHz - Turbo
Channel Best (automatic)54Mbps48Mbps36Mbps24Mbps18Mbps12Mbps9Mbps6Mbps
Tx Rate
RTS Threshold (0-3000)
Fragmentation Threshold (256-2346) kmmi
Link Distance
ACK Timeout Tuning (-100 - 100 μs)
Beacon Interval (ms)
DTIM Interval
Burst Time
802.11d Enabled
PxP Mode Enabled
Block Inter-client Traffic
Power Cap (dBm) CO: ColombiaDO: Dominican RepublicGT: GuatemalaMX: MexicoPA: PanamaPR: Puerto RicoUS: United States
Select Country
Antenna Gain (0 - 100 dBi) LONG AUTO
Preamble
Ele se conecta a outro rádio Tranzeo com antena integrada
Wireless Settings
Access Point
Wireless Mode
Primary SSID
Secondary SSID Outdoor Indoor
Location 802.11a (5 GHz) 802.11a (5 GHz Turbo)
Band 11b
1Mbps*
2Mbps*
5.5Mbps
11Mbps
11a 6Mbps*
24Mbps* 9Mbps
36Mbps 12Mbps*
48Mbps 18Mbps
54Mbps
Supported Tx Rates * indicates basic rates. All basic rates supported by the AP must also be supported by the STA or it will prevent association.
Best (automatic)6Mbps9Mbps12Mbps18Mbps24Mbps36Mbps48Mbps54Mbps
Using Tx Rate
Link Distance
PxP Mode Enabled
PxP MAC Address
Power Cap (dBm) PR: Puerto RicoUS: United States
Select Country
Preamble
PROBLEMA
No link de 3 KM eu conectei 1 note e consegui passar 2Mbps de taxa de um arquivo de 30 Megas. Na realidade preciso somente de 1 mega full pq este link so será para internet (BRT 8 megas = 1 mega real). Então já está sobrando. O problema é que no link de 30 KM quando vou fazer algum download, so ta passando 30Kbps via internet. Quando conecto o note direto no modem dsl ele passa 1 mega. ALguem pode me ajudar?
Add no msn: [email protected]
  Citação
