- Mikrotik 5.0 beta 2
Mikrotik 5.0 beta 2
What's new in 5.0beta2 (2010-Apr-30 11:35):
*) added wireless distance setting, removed ack-timeout;
*) improved 802.11 operation for outdoor distances;
What's new in 5.0beta2 (2010-Apr-29 12:10):
*) fixed sstp on x86;
*) console - removed 'delay' argument from '/system scheduler add' command;
*) console - remove 'comment=""' values from export;
*) console - updated '/system script job':
- also show active login sessions here;
- new read-only property 'type' with values "command", "login"
or "api-login" for running commands and either kind of login sessions;
- new optional read-only property 'parent' with id of the job that
has spawned this one;
*) console - changed "started" property of '/system script job' to use
local time;
*) console - new property 'type' in '/system script job'
*) console - added '/port remote-access export' command;
*) console - fixed bug that caused "cannot set ..." error when using
some properties in 'find' commands;
*) show old software id in export file header;
*) api - can supply password to '/system/upgrade/upgrade-package-source/add';
*) api - 'print' command was not showing values of some properties
such as 'servers' in "/ip/dns";
*) api - fixed api login sessions not dissapearing from '/user active' after
termination;
*) '/user active' now lists type of api connections as 'api';
*) added support for hardware watchdog on RB1000 & RB800;
*) added support for ASIX AX88xxx based USB Ethernet Adapters on RB4xx;
*) fixed problem - ipv6 traffic was not bridged if ipv6 package was not enabled;
*) fixed getting interface stats in dude;
*) fixed metarouter stability problem on RB400s & RB750s;
*) fixed metarouter - it didn't work on RB1000 with 2Gb;
*) fixed metarouter - it locked up on RB800;
*) fixed problem - SFQ queues did not work on interfaces (wireless) if none
of simple or tree queues were added;
*) fixed RB800 temperature;
*) fixed problem - WinBox crashed while opening VAP interface;
*) dhcp server - fixed possible inactive dhcp server in case of many
dhcp leases with address-pool enabled;
*) dhcp server - show non-printable option 82 agent-circuit-id and
agent-remote-id values in hexadecimal notation
(in the same way as client-id is shown);
Re: Mikrotik 5.0 beta 2
Alguem já está testando? quais suas conclusões?
Principalmente sobre a ultima acima.
Serios bloemas com minha rede...
tô aguniado aqui.. 300 clientes numa lentidão dos infernos... tô tentando voltar a versão...
na versão 5. beta 5 tive serios problemas, de instabilidade no sistema quando tinha clientes com ack auto ela ia a 100% de cpu diretão e pra piorar todas que estivem ligadas nela também sobia o processador na hora ai, os clientes caiam e os novos nem autenticavam mais... fiz um downgrade para 4.11 e fico show de bola de novo graças a Deus.
