<?php
/* PHP-NUKE: Web Portal System */
/* Copyright (c) 2002 by Francisco Burzi ([email protected]) */
/* http://phpnuke.org */
/* This is a 2 min hack of the old forum block to work with the phpBB2 */
/* port. */
/* This program is free software. You can redistribute it and/or modify */
/* it under the terms of the GNU General Public License as published by */
/* the Free Software Foundation; either version 2 of the License. */
if (eregi("block-Forums.php", $_SERVER['PHP_SELF'])) {
Header("Location: index.php");
die();
global $prefix, $db, $sitename;
/* DESC Limit numero das ultimas mensagens postada no caso esta 25 */
$sql = "SELECT forum_id, topic_id, topic_title FROM ".$prefix."_bbtopics ORDER BY topic_time DESC LIMIT 25";
$result = $db->sql_query($sql);
while ($row = $db->sql_fetchrow($result)) {
$forum_id = $row[forum_id];
$topic_id = $row[topic_id];
$topic_title = $row[topic_title];
$sql2 = "SELECT auth_view, auth_read FROM ".$prefix."_bbforums WHERE forum_id='$forum_id'";
$result2 = $db->sql_query($sql2);
$row2 = $db->sql_fetchrow($result);
$auth_view = $row2[auth_view];
$auth_read = $row2[auth_read];
if (($auth_view < 2) OR ($auth_read < 2)) {
$content .= "<img src=\"/modules/Forums/images/smiles/icon_arrow.gif\" border=\"0\" alt=\"\" title=\"\" width=\"15\" height=\"15\"> <a href=\"modules.php?name=Forums&file=viewtopic&t=$topic_id\">$topic_title</a><br>";
$content .= "<br><center><a href=\"modules.php?name=Forums\"><b>$sitename Fórum</b></a><br></center>";
