Olá PessoALL,
Gostaria de uma dica/correção caso seja necessário nestas configurações baseadas no tópico
https://under-linux.org/f226/qos-no-...mpleto-126657/ eu fiz minhas próprias acompanhando o desempenho da minha rede. Hoje estar tranquilo sem problemas, mas seria interressante saber o seguinte:
Para um LINK dedicado FULL de 4MB as configurações abaixo são boas em termo de só analisando os calculos?
[edilsonlsouza@GANTZ-AP1] > /queue tree export
# jun/01/2010 12:44:02 by RouterOS 4.6
# software id = L83V-VHHL
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=2M name=\
ServicosDaRede packet-mark=servicosdarede parent=global-total priority=1 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Ssl \
packet-mark=ssl parent=global-total priority=2 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=300k name=P2P \
packet-mark=p2p parent=global-total priority=8 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=3M name=\
BatePapo packet-mark=batepapo parent=global-total priority=2 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Udp \
parent=global-total priority=3
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Udp-100 \
packet-mark=udp-100 parent=Udp priority=1 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Udp-500 \
packet-mark=upd-500 parent=Udp priority=2 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=\
Udp-Other packet-mark=upd-other parent=Udp priority=3 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Email \
parent=global-total priority=4
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Pop3 \
packet-mark=pop3 parent=Email priority=1 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Imap \
packet-mark=imap parent=Email priority=3 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Http \
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=7M name=\
Http-Navegacao packet-mark=http-navegacao parent=global-total priority=1 queue=default
Http-1Mbyte packet-mark=http-1Mbyte parent=Http priority=2 queue=default
Http-3Mbyte packet-mark=http-3Mbyte parent=Http priority=3 queue=default
Http-6Mbyte packet-mark=http-6Mbyte parent=Http priority=4 queue=default
Http-30Mbyte packet-mark=http-30Mbyte parent=Http priority=5 queue=default
Http-60Mbytes packet-mark=http-60Mbytes parent=Http priority=6 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=1M name=\
Http-Infinite packet-mark=http-Infinite parent=Http priority=7 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Youtube \
packet-mark=Youtube parent=Http priority=4 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Outros \
parent=global-total priority=7
Outros-0bytes packet-mark=0bytes parent=Outros priority=1 queue=default
Outros-1Mbyte packet-mark=1Mbyte parent=Outros priority=2 queue=default
Outros-3Mbyte packet-mark=3Mbyte parent=Outros priority=3 queue=default
Outros-6Mbyte packet-mark=6Mbyte parent=Outros priority=4 queue=default
Outros-30Mbyte packet-mark=30Mbyte parent=Outros priority=5 queue=default
Outros-60Mbytes packet-mark=60Mbytes parent=Outros priority=6 queue=default
Outros-Infinite packet-mark=Infinite parent=Outros priority=7 queue=default
Outros-Desconhecidos packet-mark=Outros parent=Outros priority=8 queue=default
AcessoRemoto packet-mark=acessoremoto parent=global-total priority=3 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Voip \
packet-mark=voip parent=global-total priority=6 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=5M name=Hotspot \
packet-mark=hotspot parent=global-total priority=1 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Smtp \
packet-mark=smtp parent=Email priority=2 queue=default
Desde já agradeço qualquer dica.
