Lançada a nova versão!
What's new in 4.8:
*) fixed problem - WinBox crashed while opening VAP interface;
*) dhcp server - fixed possible inactive dhcp server in case of many
dhcp leases with address-pool enabled (broken in v4.7);
*) dhcp server - show non-printable agent-circuit-id and agent-remote-id
values in hexadecimal notation (the same way as client-id is shown);
*) api - can supply password to '/system/upgrade/upgrade-package-source/add';
*) console - fixed bug that caused "cannot set ..." error when using
some properties in 'find' commands;
*) api - 'print' command was not showing values of some properties
such as 'servers' in "/ip/dns";
*) show old software id in export file header;
*) added support for secondary serial port on RB800/RB1100;
Atualizem!
Até mais...
Citação
